abs module repair.
Old May 13, 2010 | 01:29 PM
Audacity's Avatar
Default abs module repair.
where do you guys send your modules to get repaired. mines locking me out of being able to scan for codes.
Old May 13, 2010 | 06:06 PM
turbo kraut's Avatar
Tech Guru
i got mine done from ian... k0mpressed, but he is mia.... all you need to do is take it out, resolded the broken solder and silicone it back
Old May 14, 2010 | 12:20 AM
Audacity's Avatar
wait a second your saying that i can do this without sending it away. i read like diys on it and they all send them away, but where they send them away to always tells me that they cant repair it.
Old May 14, 2010 | 06:11 PM
Tech Guru
mine was beeping and i sent it to kompressed, he opened it re-soldered it, and it works fine... you can send it to me and i can see if i can fix it, if i can you pay me, if not you jsut pay for it to be shipped.... but if you can solder, you can do it
Old May 14, 2010 | 08:09 PM
jiggleo's Avatar
Aren't those surface soldered? If so you're going to need more than basic soldering knowledge. If not go for it. Some basic skills, solder braid, flux and solder should be all you need.
Old May 14, 2010 | 10:13 PM
Tech Guru
to be honest i never looked in mine... but if it started again, i would be more than willing to dive in and try...... or are you talking about the case that is soldered?...if that is what your asking no....
it is the inside connections that break
Old May 14, 2010 | 11:13 PM
jiggleo's Avatar
no surface soldering is a technique used in many circuit boards
deepee58
Nov 27, 2014 11:24 AM
twainer
Jun 26, 2014 04:25 PM
matafdo
Apr 10, 2013 11:08 AM
bpoole
Apr 26, 2010 04:07 PM
Andrew149
Feb 10, 2010 09:01 PM
