Ac high pressure side
Old Apr 15, 2013 | 09:59 PM
86f250xlt's Avatar
Default Ac high pressure side
Audi newb question.
Where is the ac high pressure port? I need to charge the air conditioning in my 1996 a4 quattro.
Old Apr 15, 2013 | 10:48 PM
hartsoe1's Avatar
charge the low pressure side.
Old Apr 15, 2013 | 11:12 PM
jeckel20003's Avatar
Looks like you have to take it to a shop. No low pressure port on the 96. https://www.audiforums.com/forum/b5-...charge-106379/
Old Apr 16, 2013 | 07:23 PM
Mark C's Avatar
You have to pull the low pressure switch off the line inside the cowl, next to the battery and get a special fitting to screw back on that you can connect to a gauge manifold set. There's a shrader valve under the low pressure switch so you can take it off without the refrigerant leaking out. You then have to jump the electrical connector attached to the low pressure switch so the compressor will run while your charging.
Dallas09
Aug 30, 2011 05:57 PM
vlado182000
Mar 16, 2011 10:38 PM
TRN0412
B7 Models
9
Jun 5, 2010 08:24 AM
hahaha251251
May 30, 2008 03:14 AM
kaplar
Feb 1, 2005 09:53 PM
