AC Problems and the AC Clutch Relay
Old Jun 28, 2010 | 02:36 PM
Dallas09's Avatar
Ive got a 1.8 and thats where it is.
Old Aug 25, 2010 | 12:07 PM
Das Auto's Avatar
Hi fellas, its my first post here
to start, i have also a problem but its the opposite
my clutch its always energized
its not the clutch stucked
i did troubleshoot by removing the belt and without power or with just contact-on the clutch is disengaged
but soon as a i start the car, it engages and pumps cold air... even whem im at full hot, making my requested full hot air still cold
myy bentleys says nothing about wich of the hundreds of relays installed is
my question is, which one is the clutch relay? (number)
i will also try checking on the trinary relay
your help is very much appreciated
thanks a million guys
my car is a 2001 A4-B5 1.8T AWM all wheel drive
yours:
Fernando. (Montreal Canada)
Old Aug 25, 2010 | 12:29 PM
mab9981's Avatar
ecs link to the clutch relay i bought:
http://www.ecstuning.com/Audi-B5_A4-...trical/ES1949/
I included numbers at the on page one of this thread.
In the first picture Number 267 is the relay.
Old Aug 26, 2010 | 12:00 PM
Das Auto's Avatar
267 thanks a million brother
i'll have a look and will keep you posted
Fernando.
Old Aug 26, 2010 | 02:02 PM
Das Auto's Avatar
Ok Mab, here's what i got
1- first i did try the trinary switch, when disconnected the clutch did disengage and the fans shut-off
2- then i've found the clutch relay (as you said its 267 red)
- when disconnected, the clutch disengages but the fans keep running
i've meassured and the continuity between pins 85-86 is 69 ohm
so its not open (good), pins 30-87 are open until contact is closed, then resistance is 0 ohms
this means the clutch relay is good but
somebody is constantly sending 12v. to pin 85 closing the contact and therefore engaging the clutch
even at full hot, there's always 12v at that pin
next will be to meassure the pins at the trinary switch...
maybe it got stuck closed and ruining my hot air?
i hope i can find the schematic or wiring diagram
Thanks again Mab.
Fernando.
Old Aug 29, 2010 | 01:53 PM
Das Auto's Avatar
Got a problem
cant find trinary switch anywhere
seems that ill have to go see the stealer (dealer)
Fern.
Old Aug 30, 2010 | 01:12 PM
Dallas09's Avatar
rockauto.com has them for 80 bux. Search your car then select electrical switch & relay --> a/c trinary switch. Otherwise Napa has them for 110.
Old Aug 30, 2010 | 01:20 PM
  #18
mab9981's Avatar
I'm suprised no one has a pic of the trinary behind the headlight.
I might try to take some tonight if i can get around to it.
Hey Das Auto, i wouldn't be suprised if its not the climate control unit.
Mine had a weird problem like that, and that was the problem in the end.
Bought a used one from Shokan.com for 250 or so.
My clutch wouldn't stay engaged and the problem was the climate control unit not sending info right..
Old Sep 2, 2010 | 07:39 AM
  #19
Das Auto's Avatar
Thanks guys
ill have a look at it
but before buyng it, id like to check it
if im not mistaken, it should close contacts both at high and low pressure, isnt it?
im trying to ident it on my bentleys electric diagram to see wich pins should have continuity
if you guys have a diagram at hand (a schema) it will be great ho see it and work with it.
thanks a million for your assistance
Fernando
Old Jun 25, 2012 | 08:38 PM
  #20
taylor797's Avatar
Where is this relay panel located? I have looked for an hour to find the location and I cannot find it anywhere. Any help would be appreciated. Thanks
