Acceleration Problem and Suspension Help
I have two things that are bothering me and i'm hoping you guys can help me out.
1. When i'm accelerating at a normal pace i feel i slight stutter at about 3k rpm and then it goes back to normal. This only happens in 2nd and a little in third. Any ideas? BTW i just changed my plugs, fuel injector o-rings, and one coil pack.
2. I have a thump. Whenever I am turning the wheel to the right i hear a pretty loud thump thump thump until i straighten up or turn right. Another aside i have a bad power steering pump but the noise seems to be coming from my front right tire. I can also feel it through the gas pedal everytime it thumps. Again, any ideas?
i had a misfire code bc i'm a retard and didnt plug the fuel injector harnesses in all the way so i thought it was the coil pack and replaced it and the plugs and then i noticed the wireharness after the misfire didn't go away. i have no CEL but last time i checked the codes i got a code saying a have a bad knock sensor.
and no there was no stutter before
If the knock sensor code didn't come back I wouldn't worry about it. I'm guessing that you have a fuel injector that isn't seated quite right.
You can do it yourself but it's really f'in messy and you have to remove the pinch bolt. I think there's a right up on Audiworld but I didn't use it.
If you have the money and don't have much experience working on cars I would recommend that you pay someone to do it.
