Air Bag Light
Old Jun 9, 2010 | 09:15 AM
MrEvans86's Avatar
Member
Default Air Bag Light
My air bag light kicked on yesterday, Just of no where. I don't know much about the electronics on this car yet but i'm assuming there is a sensor somewhere that went bad.
Old Jun 9, 2010 | 09:25 AM
screamin demons's Avatar
Your car has 10 air bags in it. Any one of these can cause the light to come on. It's usually the seat airbags that the connectors get loose and cause the light to come on. If you have VagCom you can reset this.
Old Jun 9, 2010 | 02:40 PM
Munzter's Avatar
If you're lucky, it is a bad connection, likely under one of the front seats. If you're unlucky like me, it is the Airbag Control Module, which are about $700 for the part. If you get a memory fault code from the ACM, then you're going to have to replace it. I got mine replaced because I was sick of the airbag light being on and didn't know if my airbags would fire if I got in an accident.
Old Jun 9, 2010 | 05:17 PM
Dallas09's Avatar
Yep you need a VAG COM.
Old Jun 9, 2010 | 05:35 PM
briesa4's Avatar
I fatassed mine on recently most of them go bad from the connector under the drivers seat.
My code couldnt be cleared and I have yet to try and fix the connection
pm Imthedevil he had the same issue
Old Jun 10, 2010 | 01:47 AM
A4 2000's Avatar
I had that light turn on out of nowhere too the other day. Luckily it magically turned off about 30 seconds later.
Old Jun 10, 2010 | 03:31 AM
Dallas09's Avatar
Sounds like a communication issue with the instrument cluster.
MULEPERFORMANCE
Feb 23, 2010 06:31 PM
blanthony
Mar 25, 2006 01:18 PM
