Air box mod
Hey can someone give me the links for the air box mod, the one in the newbies guide has no pics...... i need pics or can someone give me instructions... also does it make the turbo more audible?
it does make the turbo more audioable
and it's better to have a dermal tool trust me i did it on mine and it will go way faster and also if you want you can put a piece of screen on the opening you did to protect it...Either way it's your choice i put two screen's one inside the fender where i did the opening and a other one in the hole that i made on the air box
and hear is one
http://forums.vwvortex.com/showthread.php?2260654
and it's better to have a dermal tool trust me i did it on mine and it will go way faster and also if you want you can put a piece of screen on the opening you did to protect it...Either way it's your choice i put two screen's one inside the fender where i did the opening and a other one in the hole that i made on the air box and hear is one
im gonna make bigger holes in the fender but yea i might double screen it i live in Iowa and it snows and rains a lot, gonna be careful. Thanks for the link, how did you do it?
and some down time for your car (If you dont know where the MAF is it's at the top portion of the airbox it's a littil small tube shaped thing and then just reconnect everything and boom your ready to go.Oh and when you turn it on for the first time turn the key but dont turn on the car wait a minute and then turn on the car and wait....the car will sound different and the RPM's will be elevated a bit but that's just the MAF and the ECU adjusting to all the new air that you just gave it let it idle and for a while and when everything goes back to normal give it a test
You can hear the turbo spool a little more, other than that tho your right our airbox rocks!
