Alignment
Old Feb 19, 2008 | 03:55 PM
aramkim's Avatar
Default Alignment
How important is getting you car alignment done?
How often should it be done?
How much will it cost?
My steering wheel is starting to tilt a little so I'm just curious.
Old Feb 19, 2008 | 07:27 PM
vgo's Avatar
vgo
Default RE: Alignment
check your tire pressures first before taking it to the shop to get it aligned. only get it done when needed, theres no set marker on when to have it done.
Old Feb 19, 2008 | 07:31 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: aramkim
How important is getting you car alignment done? Very
How much will it cost? $70-90 depeding on where its done
Theonly time you need to have it done is when you change ride height or remove the axles (etc). Also if you hit something hard, it can throw off the alignment
kevintt
Jun 21, 2008 05:25 PM
kwaskow
May 23, 2008 06:08 PM
grrrrrrr
May 9, 2008 07:41 PM
wings7351
May 24, 2007 01:42 PM
ouTTie914
Aug 17, 2006 10:48 PM
