Alternator replacement
Old Feb 19, 2010 | 10:35 PM
rubanokuss's Avatar
Default Alternator replacement
Does anyone have any manual for alternator replacement on 2001 audi b5 1.8t Q.
Old Feb 19, 2010 | 10:45 PM
auditech79's Avatar
Its as easy as removing the belt and unbolting it, should be pretty straight forward.
Old Feb 19, 2010 | 11:00 PM
rubanokuss's Avatar
I dunno , that sounds pretty bad. I would just go to mechanic , but with all constant repairs im doing i might as well start learning it myself. And start from timing belt sounds kinda harsh. If somebody had like step by step instruction that would be helpfull.
Old Feb 19, 2010 | 11:04 PM
euro_2nr's Avatar
Just tackle it bro. My rookie year it took me 5.5 hours to do. Second A4 I did, it went by in 20 mins.
Old Feb 19, 2010 | 11:07 PM
euro_2nr's Avatar
I'm not aware of any DIY's. Pick up a Haynes manual and it'll give you hints.
Biggest tip: take off the fan. Just hold it with a wrench and unbolt it so you can push it forward enough to get the longer support bolt for the alternator. Besides that, just take off the coolant hose and make sure you replace whatever antifreeze you lose. EZ.
Old Feb 19, 2010 | 11:17 PM
hiwords's Avatar
you're not taking the timing belt off, just the alternator belt. it's not going to affect your engine timing at all. just go at it but have a second car to go to the parts store because you'll forget something you needed to buy lol
Old Feb 20, 2010 | 12:00 AM
auditech79's Avatar
Oh yeah you're not touching the timing belt, you just need to remove the tensioner on the serpintine belt and slip it off the alternator. Let the belt hang and then tackle the alternator, it shouldn't be that hard at all. Now an alternator on an S4 4.2L..............
A4 2000
May 23, 2016 05:09 PM
mapper01
S4
Nov 21, 2013 07:27 PM
havok91
Dec 13, 2009 09:02 PM
Mhmara
Sep 12, 2007 03:21 PM
jonbelles
Feb 2, 2007 01:21 AM
