Ambient Temp Gauge Acting Flakey
Occasionally, the ambient temperature gauge goes way off, like showing -20 degrees when it's 75 out. This is throwing off the cabin climate control. Any ideas diagnosing the problem? Thanks
01/B5/AWM |
Check your ambient temp sensor or connection
To be a little more specific, the ambient temp sensor is the likely cause of your issues. The sensor should be clipped to a plastic bracket on the end of your power steering cooler, the looped metal tube visible in front of your AC condenser, which is in front of your radiator. Start by wiggling the connector to see if it's just loose. If that doesn't fix the problem you may need to replace the sensor.
If you end up needing to replace it, you can find a new one here: Audi B5 A4 Quattro 1.8T > Search > Temperature Sensor > ES#7330 B5 Outside Temperature Sensor - 8D0820535 |
dancing bear?
CCA4, is that a dancing bear in your out-building?
Originally Posted by hartsoe1
(Post 1406738)
Originally Posted by CCA4
(Post 1406783)
LOL somethin like that
