Ambient Temp Gauge Acting Flakey
Old Aug 12, 2009 | 08:33 PM
The Bub's Avatar
Default Ambient Temp Gauge Acting Flakey
Occasionally, the ambient temperature gauge goes way off, like showing -20 degrees when it's 75 out. This is throwing off the cabin climate control. Any ideas diagnosing the problem? Thanks
01/B5/AWM
Old Oct 7, 2012 | 04:17 PM
audidoc2's Avatar
Check your ambient temp sensor or connection
Old Oct 7, 2012 | 07:12 PM
CCA4's Avatar
To be a little more specific, the ambient temp sensor is the likely cause of your issues. The sensor should be clipped to a plastic bracket on the end of your power steering cooler, the looped metal tube visible in front of your AC condenser, which is in front of your radiator. Start by wiggling the connector to see if it's just loose. If that doesn't fix the problem you may need to replace the sensor.
If you end up needing to replace it, you can find a new one here:
Audi B5 A4 Quattro 1.8T > Search > Temperature Sensor > ES#7330 B5 Outside Temperature Sensor - 8D0820535
Old Oct 7, 2012 | 09:10 PM
hartsoe1's Avatar
Default dancing bear?
CCA4, is that a dancing bear in your out-building?
Old Oct 8, 2012 | 08:00 AM
CCA4's Avatar
LOL somethin like that
Old Oct 8, 2012 | 09:52 AM
jonbonesjones's Avatar
Moderator
i hope this guy isnt a kid asking about the bear in chris' garage
Snipermatt
Aug 9, 2010 03:05 AM
kbrookst
Oct 24, 2009 06:37 PM
Armenian
Apr 1, 2009 01:42 AM
IDUA ORTTAUQ 6A
Oct 13, 2007 03:43 PM
int76
Aug 16, 2007 09:30 PM
