another depo lights question
Old Mar 24, 2008 | 10:30 AM
flyromeo3's Avatar
Default another depo lights question
So im opting to by a set of 4pc depo lights for my 99. Currently I have the stock headlamps which suck but I also have city lights.
The depo projectors im looking at :
http://cgi.ebay.com/ebaymotors/AUDI-...spagenameZWDVW
Now by the high beams there seems to be a small hole for the bulb to be inserted but my question is do I have to cut any wires or so?
Is it simply just swap the bulbs out and connect the headlamps and thats it?
Old Mar 24, 2008 | 10:48 AM
sineo's Avatar
Default RE: another depo lights question
It's a direct swap.
Old Mar 24, 2008 | 10:50 AM
SAudi's Avatar
no they're made for H7 bulbs so you just swap everything over, teh only issue is if you have pre face lift fog lights which are built into the headlamp then your gonna loose those unless you do get post face lift fog light recesses and replace them with yours.
Old Mar 24, 2008 | 11:36 AM
flyromeo3's Avatar
SAudi:, I have fog lights in addition to the city lights / (headlamp fog lights ). They are on a separate switch so I guess all that will be retained when doing the swap.
Also, where can I buy the screws that hold down the headlamp ( I know already that my passenger side is going to be a bish to remove) definitely will be stripping that bolt.
Can I get to the bottom headlight bolt without removing the bumper? maybe a 90 degree angle driver or something
Old Mar 24, 2008 | 12:20 PM
MrFlippant's Avatar
On those DEPO lights, the little city light (which fits into the hole in the bottom of the high beam reflector) is wired into your existing fog light circuit. I plan on eventually rewiringmine so thatthe city lights are hooked up to my parking lights, and then install facelift fogs and wire them to the existing fog light switch.
I managed to get at the bottom bolt alright with the bumper on, it's just a tight fit is all.
Old Mar 24, 2008 | 01:53 PM
trevor303's Avatar
ORIGINAL: flyromeo3
yea, you can get to it...when i did mine it wasn't any problem.. i had a long screwdriver that was angled towards the bolt, but not angled enough to where you coudnt grab onto it
Old Mar 24, 2008 | 03:54 PM
flyromeo3's Avatar
anyone know where I can get the headlight bolts? ( the two that go on top of the housing ) Im definitely going to strip the head trying to remove it cause it looks rusty.
Old Mar 24, 2008 | 03:58 PM
pimphell's Avatar
spray it first with wd-40 if there rusty
Old Mar 24, 2008 | 04:19 PM
MrFlippant's Avatar
Mine came off pretty easily with an electric impact wrench.
Old Mar 24, 2008 | 04:58 PM
SAudi's Avatar
ORIGINAL: flyromeo3
you can on the 4 piece, just remove the corner markers and theres the bolt.
