any ideas
Old May 25, 2011 | 10:12 PM
Jhonathan978's Avatar
Default any ideas
i have a 97 a4 and i'm trying to mod my dash to fit a double din raido any ideas?????
Old May 26, 2011 | 05:43 AM
ObnoxiousDrunk's Avatar
Search Audizine.com for Double Din swap. I'll post the direct link later if you can't find it. The swap is easy but not cheap. I've completed the swap so I can give you a few pointers. Let me know.
Old May 26, 2011 | 06:56 AM
This is the direct link to everything you need to know about doing this swap.http://www.audizine.com/forum/showth...Console-Thread
As I indicated earlier, the swap is easy but can be pricy. Most of the parts can be found on eBay or in classifieds (AudiForums, Audizine, VWVortex, etc.) or even in a double din part out (like I found mine). Again, if you have any questions feel free to PM me.
Old May 26, 2011 | 08:16 AM
spcmky's Avatar
I agree with Obnoxious. The cheapest part of my swap was the radio. It took me a while to find the environment controls for the new setup. If you get the radio off ECS Tuning be sure you select the correct one. They have a couple of options.
Old May 26, 2011 | 08:22 AM
My HVAC controller was pricy as well and it still is the wrong version, but it works so I'm happy. Take a few days or weeks to compile all the parts so you don't end up doing the work twice like I did at times.
The next most difficult part will be the upper console surround. It will likely be pricy and tough to find.....but keep at it.
If you go the ECS tuning or eBay route for the radio unit be sure you get the correct unit. If you are not worried about keeping everything stock, there should be no issue.
Old May 26, 2011 | 07:39 PM
I want to thank you guys a lot for the ideas i have a double din after market radio. Question do i have to cut wires or do the connectors for the heat and top buttons fit in to the new one
Old May 26, 2011 | 09:09 PM
By heat, I assume you mean the HVAC controller. Your existing wiring should work as most of mine did, but I had more issues as mine was a '96.
You will have to source new buttons for you fog lights as well if they are not the facelift variety, but again, your existing wiring will work.
Old May 28, 2011 | 02:05 PM
thanks a lot i am going to start looking for everything now i have pic up soon hopefully
Old May 28, 2011 | 04:53 PM
Sounds great, keep us posted.
Old Jun 13, 2011 | 08:58 PM
OK I've search all over found almost everything i needed but could not find the radio cage or a black console so I've decided to go with plan B. I'm going to keep my havc unit remove my ashtray and lighter put my hvac unit in there and that will give me the space i need above to install my doubble din radio
