any interest in a control arm DIY?
Old Mar 30, 2013 | 04:44 PM
redline380's Avatar
Legal Moderator
Default any interest in a control arm DIY?
i'll be changing out all my front end control arms, uppers and lowers on both sides as well as inner and outer tie rods tomorrow and monday. if there is interest, i'll take pics and work on a DIY. i guess i've never done it so it will kind of be a learning experience for me too, but i'm sure i could write up a good DIY
Old Mar 30, 2013 | 04:52 PM
MrSnickelsnizer's Avatar
What a way to spend passover. The more write ups the better in my mind. I wish I would have taken a couple pictures of it, when I changed mine. I ran into a couple issues I think most write ups don't prepare you for. Like when the bottom control arms, or top for that matter, seize to the hub. I had to jack the car up and sledgehammer both sides out. The top ones were a nightmare and a half. So yeah do it if you have the patience
Old Mar 30, 2013 | 05:03 PM
redline380's Avatar
Legal Moderator
my front end has been apart enough. when i put my coilovers in, i was smart and flipped the front upper control arm bolt around so it can be pulled out in case i ever wanted to do control arms. it enables the bolt to be removed without taking the whole strut assembly out. and my pinch bolt has been replaced with a stainless one for over a year. if anything else is seized, ill just use an air hammer. i will probably make it look easier than it will be for most, but i figured a write up may help some out
CCA4's Avatar
I'd say go for it. Control arms, tie rod ends, sway bar end links, and shocks are all on my list for this spring as well.
Old Mar 30, 2013 | 05:50 PM
hartsoe1's Avatar
there is an excellent 4 part control arm DIY right here on the Forum.
Old Mar 30, 2013 | 10:50 PM
redline380's Avatar
Legal Moderator
well if there is already a diy guess theres not much point in doing another. ill havent seen it but ill look now
slukepunk
May 19, 2011 12:37 PM
flynnr
Jul 11, 2010 11:43 PM
SchlafwagenS4
Feb 7, 2008 03:14 PM
Nanner
Feb 2, 2007 06:30 PM
