Apr tune
Old Feb 2, 2012 | 01:17 AM
sb301's Avatar
Exclamation Apr tune
I went to a local APR dealer yesterday. After driving for about 30 miles, I noticed my check engine light came on. Has any one on here experienced this problem after getting tuned? Is there a warranty on the software? Any input would be appreciated. Thanks!
Old Feb 2, 2012 | 01:40 AM
Audifanseattle's Avatar
what did you get it tuned for?
Old Feb 2, 2012 | 07:46 AM
CCA4's Avatar
I would definitely take it back to them and have them check it over. Might not be related, but I wouldn't take the chance.
Old Feb 2, 2012 | 09:01 AM
murdox's Avatar
Stock DV took a dump? Would that trigger a CEL?
Pretty sure you have to warranty everything you do in your shop if you are certified to tune with APR software. Take it back to them immediately.
Old Feb 2, 2012 | 12:39 PM
sb301's Avatar
Stage 1 tune.
Thanks guys. I'm at work and unfortunately I can't leave to go to the shop. I called and explained my situation to them. And was put on "hold" for 20 minutes. I finally hung up and called back and of course, they didn't answer. I have never had the check engine light come on untill I did this.
Murdox- I was wondering the same thing. I'm not sure if that would trigger a cell or not.
Old Feb 2, 2012 | 01:12 PM
rodhotter's Avatar
APR tune would not cause a CEL unless it was souldered in, its a very delicate operation and can go BAD, not usually but it happens, i know from experience
Old Feb 2, 2012 | 02:32 PM
murdox's Avatar
Op, did you replace the stock dv when you got the tune? If you didn't, I would replace it in the near future. Someone on here told me once that the stock dv failed the same day he got a stage 1 tune. Replace it regardless if its the culprit.
Is the car boosting corectly? Jerky motion at all? If you don't have a boost gauge id get one of those too. Stage one boosts to ~19 psi then tapers from there ( when you floor it at least )
Try to get it scanned to see if it pulls any codes? Maybe you popped a boost leak somewhere with all the extra psi running through the car.
Old Feb 2, 2012 | 02:51 PM
MetalMan's Avatar
Could also be a misfire... When chipped it's common to go to a "colder" heat range spark plug with a gap of 0.028" instead of the stock 0.032" gap.
Old Feb 6, 2012 | 11:48 PM
sb301's Avatar
So I opend my hood prior to taking it to the dealer where I got it tuned, I realized a check valve needed to be replaced. I replaced one of the valves and the check engine light went off the next day.
Old Feb 7, 2012 | 04:58 PM
vollkommenes's Avatar
Default dont knwo fi it was said
but coil packs,diverter usually go
