audi a4 problem
Old Dec 28, 2009 | 06:39 PM
wagner1968's Avatar
Default audi a4 problem
Heyy i went and test drove a 99.5 audi a4 with a garret gt28rs turbo kit. When i was driving it as soon as you would start building boost the car would start missing but it still pulled 22 pounds. it had a cell so i plugged my scanner in and this is what i got
p1613
p0300
random/multiple cylinder misfire
p0303
cylinder # 3 misfire
p0304
cylinder #4 misfire
p1300
ignition system or misfire
i'm new to audi but i'm thinking bad coils or a ignition control module? please help
Old Dec 28, 2009 | 06:47 PM
TeeterTawter's Avatar
it could be the coils, could also be the spark plugs
I run an equivalant set up. I run a T28 with full boost at 24psi and run NGK BKR7E spark plugs gapped at 0.28".
Old Dec 28, 2009 | 06:54 PM
wagner1968's Avatar
i just don't want to buy it if its a bigger problem than that whats worse case scenario and shouldn't the cell have been flashing
Old Dec 28, 2009 | 08:04 PM
wagner1968's Avatar
it runs smooth untill about 3 grand when your building boost injector?
Old Dec 28, 2009 | 10:09 PM
dragonrage's Avatar
Check the gap on the spark plugs. It should be .028, not the standard .032. Also, they'll need changing often so they could be fouled. Find out who did the tuning. Maybe the fuel filter needs changing as it's more and more restrictive with more boost.
Old Dec 28, 2009 | 10:39 PM
wagner1968's Avatar
if its nothing more serious thats good
Old Dec 30, 2009 | 02:08 AM
wagner1968's Avatar
the p1613 code is known to come up if an automatic trans ecu is in a manual
car atleast this is what i have found out. So could this spitting and sputteriing be from a fuel cut while shifting and thats why its throwing thees codes but this kid has been driving the car for a year with none of theese problems till now?
Old Dec 30, 2009 | 09:29 PM
why would teh fuel be cut while shifting?? never heard of that ever happening.
how long have you known this kid? if you never met the guy, and hes telling you that it drove fine until now. hes probably bullshitting you.
Old Dec 31, 2009 | 11:09 AM
wagner1968's Avatar
well what problems could this cause then
Old Dec 31, 2009 | 11:18 AM
CCA4's Avatar
just throwing out ideas, but is it possible any of those codes are old? Maybe clear them, take it for a spin and see what happens? You could also try a TB alignment and see if that helps with the missing. Personally I'd put my money on the ignition control module, i thought the cel ALWAYS flashed for misfires?
