Audi a4 taking a lot of cranking to start
Old Jul 18, 2012 | 03:04 PM
Pbcrazy's Avatar
Default Audi a4 taking a lot of cranking to start
My 98 Audi A4 1.8T is taking along time to start now. Has a great new battery, and it seems to be getting worse everytime I start it regardless of if the engine is hot or cold. It sometimes takes up to 10 seconds off turning the key continuously before it will fire up. Im really confused
Old Jul 18, 2012 | 03:10 PM
jonbonesjones's Avatar
Moderator
Coolant temp sensor
Old Jul 18, 2012 | 03:59 PM
Pbcrazy's Avatar
The sensor on the dash is where it's suppose to be, and let me add I just replaced the water pump
Old Jul 18, 2012 | 04:21 PM
Moderator
my coolant temp sensor was bad and my guage read fine. Car started every time sometime it took 10 seconds sometimes it took 30 sometimes it took 3 seconds. Also when starting if you hold the pedal to the floor it shuts off the injectors and your car will start. The coolant temp sensor cause the car to try to start rich as a ****.
Old Jul 18, 2012 | 04:38 PM
Pbcrazy's Avatar
Sweet ill replace it, it's $10 and easy to replace (as easy as sometime for an Audi can be to replace anyways)
Old Jul 18, 2012 | 04:51 PM
Moderator
ha make sure you pull the old o ring out and don't have two shoved in there. New o-ring and new clip also.
Old Jul 18, 2012 | 04:57 PM
Pbcrazy's Avatar
Is the new clip necessary? My local autozone had the sensor and oring but I don't see a clip
Old Jul 18, 2012 | 05:00 PM
Pbcrazy's Avatar
I'm on autozone.com and the temp. Coolant sensor they have has a round connector, on the directions I am looking at its a square connector. They offer a square one for my car but it's just a temp sensor. Which one do I need?
Old Jul 18, 2012 | 05:09 PM
Moderator
check your car if you need square get square round get round they are the same thing, clip not necessary unless you break yours
Old Jul 18, 2012 | 05:16 PM
Pbcrazy's Avatar
Is the coolant sensor under the coolant expansion chamber or on the engine?
