audi b5 sat now will crank but not start
Old Mar 23, 2013 | 06:20 PM
f.rabert's Avatar
Lightbulb audi b5 sat now will crank but not start
so i let my Audi sit for a week in the cold forgot about the vent on the carbon fiber hood and it snowed melted and froze all on the ignition coils.Im assuming that's the problem,the fuel pump is kicking on and we unscrewed it and it is getting fuel in the rail,CAN IT BE THE CPS OR crankshaft position sensor, it is getting compression,theere is just no spark at all....turned the key to acc stuck a test light in the ignition coils nothing lit up any help at all trying to figure this out is suppose to be kind of nice tomorrow
Old Mar 23, 2013 | 09:49 PM
f.rabert's Avatar
Angry
can someone please help me ):
Old Mar 23, 2013 | 10:09 PM
EthanB5( auditek)'s Avatar
Tech Certified
ok so. car ran 100% when you parked it? sat for a week? and holes in your CF hood engine got wet?.....
and you dont have power to the cpil packs? and 1.8 or 2.8?
Old Mar 23, 2013 | 10:42 PM
f.rabert's Avatar
Yes sir and a 2.8 I can't figure this out
Old Mar 23, 2013 | 10:43 PM
f.rabert's Avatar
I can only think crank cam sensor froze or went bad or the coil pack and temp sensor that's what I have been reading on,all day lol my eyes are killing me
Old Mar 23, 2013 | 10:47 PM
f.rabert's Avatar
The coil pack prob had about half inch thick ice on it,I completly forgot about the vent in the hood when I parked it
Old Mar 23, 2013 | 11:01 PM
Tech Certified
yea.. that water probably damaged some wiring or something... do you have a scanner to check for faults? did you check to make sure that there is power before the wires?? to the coil packs"
Old Mar 23, 2013 | 11:06 PM
Tech Certified
wait the coils are connected to the ignition ecm ..that may have got damaged from the water/snow/ice/ freeze....but really with no faults its hard to say..
Old Mar 23, 2013 | 11:09 PM
f.rabert's Avatar
No codes are popping up at all,I'm guessing cool pack,it will sit there all day and crank but won't turn over
Old Mar 23, 2013 | 11:14 PM
Tech Certified
did you check to see if the coil packs are getting power?
or if the the module is? because if they are getting power but not sending it thru the wire i'd say yes to getting new coil pack/ module.. or you could always go SWAG method and just throw parts at it
