Audi gurus help
Old Jan 15, 2011 | 07:33 PM
twilliams83's Avatar
Alright i checked audidiy.com and they only have one for manual. Ill check the others right now
Old Jan 15, 2011 | 07:51 PM
i checked both sites and cannot find the diy
if anyone has the link or knows where to find it it will be greatly appreciated.
Old Jan 15, 2011 | 08:09 PM
FASTER's Avatar
Tech Slut
I believe this should be the same.
http://www.vaglinks.com/Docs/VW/Pass...Change_DIY.pdf
Old Jan 16, 2011 | 09:04 AM
Mark C's Avatar
If you drained 4 quarts of transmission fluid out by mistake, did you put 4 new quarts of oil into the engine and now have 9 quarts in the engine? If so get the extra 4 out before running the engine.
Old Jan 16, 2011 | 11:11 AM
dragonrage's Avatar
I don't understand how people do this. The engine oil bolt is completely obvious.
Old Jan 16, 2011 | 01:39 PM
Msnickbroderick's Avatar
Actual WIZARD
http://forums.audiworld.com/showthread.php?t=339022
I swear this is the 12th time I've posted this. Search correctly next time
Old Jan 16, 2011 | 05:19 PM
vgo's Avatar
vgo
+1 probably the 4th thread i've seen about this.
Anyway, to the OP, did you originally plan to drain the oil without changing the oil filter? Because if you did see the oil filter, there would have been an oil drain bolt around the area.
Also, after you drain and refill the engine with oil, you have to check the dipstick just to double check you have put the right amount. If it's way pass the "FULL" line on the dipstick, then some where during the procedure, you have made a mistake.
Old Jan 16, 2011 | 06:06 PM
  #18
so i just finished putting the new transmission fluid in, not as hard as it seems. I followed the link provided by fastera4theyyurs
and i redrained the oil and changed the oil filter.
to the people who actually helped thank you.
Old Jan 16, 2011 | 06:23 PM
  #19
FASTER's Avatar
Tech Slut
Glad its taken care of... its an embarrassing mistake, but they happen. I forgot to tighten a tensioner back up on a customers car once, and the belt didnt squeal a bit when I took it for a short test drive. But of course as soon as the customer got in it to leave, it loosened up and squealed like hell. I felt like such an *******.
Old Jan 16, 2011 | 06:36 PM
  #20
ya it is embarassing but at least i got new transmission fluid out of it hahaha
