Audi won't start
Old Jul 24, 2014 | 11:29 AM
zero-o-matic's Avatar
Default Audi won't start
car worked fine last night/ now this morning it won't. the batteries good (fully charged) and when i go to turn the ignition, it just makes a very quiet click sound 3 times then only the accessories turn on. had no problems starting last night/ now all of a sudden nothing. love these cars but random **** like this is starting to get annoying.
Old Jul 24, 2014 | 03:43 PM
no start no crank.
Old Jul 25, 2014 | 09:38 AM
A4TurboGuy's Avatar
What year? What engine? What tranny? AWD?
Old Jul 26, 2014 | 09:39 AM
mtroxel's Avatar
How old is the battery? Just because it shows 12.6 volts at rest doesn't mean it can produce 12-ish under load. Have you tried jumping it?
If you take that out of the equation, my vote is for a bad spot on the starter's commutator...time for a rebuilt starter. But first take the battery to a shop and have it tested under load.
Old Jul 26, 2014 | 10:35 AM
bradtyler02's Avatar
Most likely just needs a new starter, but follow his advice^. Also, if you decide to take the starter in to be tested, don't trust the results. I took two bad starters down, and they both tested fine. The run enough amps through them to make them spin anyway.
Old Jul 26, 2014 | 02:59 PM
1997 a4 1.8 awd. battery is about 3 years old. i get full power. just no crank at all.
Old Jul 26, 2014 | 03:02 PM
i rebuilt the engine about 6 months ago/ new timing belt/waterpump/belts/ valve cover gasket/ crank seal/ cam seal/ you name it i re did it. (spark plug broke and bounced in cly 4)
tested the battery at work (dealership) and it tested fine.
Old Jul 26, 2014 | 07:06 PM
put the car up on ramps or jack stands and tap on the solenoid a few times with something solid (not metal though) and see if it will start after that.
mtroxel's Avatar
If you have 9.5 volts under load, then it's either the cables to the starter (not terribly likely) or the starter (far more likely).
