B5 -98 2.6 quattro can't fit 18" wheels
Old Nov 13, 2010 | 11:26 AM
Muksimp's Avatar
Default B5 -98 2.6 quattro can't fit 18" wheels
Hello
I bought a set of 18" rims with winter tires, audi s-line replicas and can't seem to fit em on my car
my mate had same wheels on he's B5 and i have seen 19-20" on B5 so it's really strange. And my summer tires were sitting on 18"
So here's the problem, i fitted the first wheel in rear and noticed chassis joint is touching the tire, just and just from the inside edge.
Here's picture to demonstrate
EDIT: Tires are 245/40/18
Old Nov 13, 2010 | 11:43 AM
CCA4's Avatar
what size tires?
Old Nov 13, 2010 | 11:52 AM
SVT_BRYAN's Avatar
More importantly, how did you get a 2.6 liter engine!?!? That must be extremely rare! :P
Old Nov 13, 2010 | 12:23 PM
chocalotstarfish's Avatar
Super Moderator
My guess is the tire size is too big OR to high of an offset on the wheels. Post spec on tires and we could help ya since I think tires are the issue!
Old Nov 13, 2010 | 12:27 PM
Muksimp's Avatar
Tires are 245/40/18
And i got the 2.6 engine by living in Finland, here it's the most common B5 v6 engine
Old Nov 13, 2010 | 12:30 PM
Mike-2ptzero's Avatar
Sounds like the offset on the wheel is wrong, might need to see if a spacer will help it fit.
On the B5 we cant run a tire that is much taller then 25", if it is taller then that it will hit the arm. What size is the tire that is on the wheel?
Old Nov 13, 2010 | 12:50 PM
Super Moderator
That's a wide tire! Depending on the offset of the wheel that's your issue. Just a side note... Tires that wide are no good for winter! wide tires are great for summer but in the winter a thinner tire will get more traction than a wide one.
To find the offset of the wheel it should be stamped on the inside of the wheel as ET## or ##ET
Old Nov 13, 2010 | 12:51 PM
hiwords's Avatar
245/40/18 will sure not fit. i had the same problem. a spacer should take care of the problem on the inside however, you'll rub the fender. i actually chipped my paint in a couple of places
Old Nov 13, 2010 | 01:25 PM
Muksimp's Avatar
Fenders won't be a problem since i have stock coilovers and alot of clearance, but yea will be installing 5-10mm spacers
Old Nov 13, 2010 | 05:23 PM
The width is not the issue, its the side wall height. Tires are just way too tall since that size is 25.75" tall. To run 245 on a 18" wheel you need 245/35/18 tires which is 1" shorter at 24.75".
Height of a set of 245/40/17's are pushing it and thats on a 1" smaller wheel.
