b5 a4 2.8L FWD thermostat
Old Nov 12, 2008 | 10:55 AM
SuperSquid's Avatar
Default b5 a4 2.8L FWD thermostat
fail open or fail closed?
running awfully cold.
Old Nov 12, 2008 | 10:56 AM
Tweaked's Avatar
I've seen both, but more commonly open.
Pull the small hose to the overflow tank while the car is running. Do you have flow?
Old Nov 12, 2008 | 11:00 AM
SuperSquid's Avatar
i'll try to check that this afternoon/evening between work/class or after class.
Struggling to get over 1/4 up the water temp gauge in a 15-20 mile suburban commute. plenty of stop lights. I wouldn't think weather between 0-5* C would keep the car from coming up to temp w/o the thermostat being fail open and needing replaced.
Old Nov 12, 2008 | 11:30 AM
Tweaked's Avatar
Agreed. It's fairly inexpensive to replace. Have you done wp, tb, etc, etc?
Old Nov 12, 2008 | 11:38 AM
SuperSquid's Avatar
Nope, and have no plans to right now. Need to get it running right before i worry about that stuff.
My other issue i believe to either be MAFS or fuel delivery. really think just a MAFS but have had zero time to diagnose it other than driving.
Old Nov 12, 2008 | 12:15 PM
somebody5788's Avatar
Inexpensive to do it yourself or by a shop? We have a passat 2.8 30v in the shop right now having this exact job being done and it doesn't look cheap or easy to me.
Old Nov 12, 2008 | 12:21 PM
SuperSquid's Avatar
thermostat looks like a $20-$40 part depening on where you get it and is a pretty damned simple job to DIY.
Old Nov 12, 2008 | 02:36 PM
hb972.8q's Avatar
what year? i know on the 96 and 97 the therostat is behind the water pump and is a real pita. changed mine when i did the timeing belt and all other stuff
Old Nov 12, 2008 | 02:38 PM
SuperSquid's Avatar
d'oh. thought that was in there.
it's a 96.
Old Nov 12, 2008 | 02:48 PM
hb972.8q's Avatar
i would get the whole kit from ecstuning. best off changing it all at once
