Bad head gasket?
Old Aug 28, 2008 | 11:39 PM
jrzroots's Avatar
Default Bad head gasket?
97 a4 1.8.....when the car starts it idles rough for a minute or so then it goes away. when i accelerate i.e. on ramp....it runs rough. The dealer said the head gasket was leaking. but the oil looks clean. they gave me an estimate of 1,900$. does anyone have opinions on other possible problems. The dealer said it was misfiring beacause of the gasket. it has a 150k on it.
Old Aug 29, 2008 | 12:00 AM
airguard350's Avatar
Tech Guru
My 2.8 would start then die or idle rough, did you check your plugs? When I checked mine, they were pitch black.
Old Aug 29, 2008 | 12:03 AM
onepoint8tee's Avatar
Diagnose the misfire first. It can be the cause for roughness. Get the codes and see which cylinders are missing and go from there. After you rule out all the things that cause a misfire like the icm, coil packs, and plugs, then consider the head gasket. Has the engine ever overheated that you know of?
Old Aug 29, 2008 | 04:33 PM
jrzroots's Avatar
i bought the car used about 7 months ago and I have no idea if it has ever been driven while overheated.
AudiTurbo
Jan 7, 2014 08:03 AM
evilkowz
10
Jun 22, 2010 11:48 PM
brian58503
Apr 13, 2009 01:22 AM
milo55041
Apr 23, 2008 12:47 PM
louellison
Oct 28, 2006 11:30 AM
