Belly Pan Screws
Old Jun 17, 2014 | 07:35 PM
Steve777's Avatar
Default Belly Pan Screws
So when I got my 01 A4 Avant, there were only 3 screws holding the belly pan on. Not a big deal, but I hear a rattle over bumps and a quick inspection down there only the edges of the belly pan were loose. Simple enough fix, get some more of those special screws with the cork screw like thread and very wide flat head.
Called my local Audi dealer and they want $8 each for those screws!!! They have got to be kidding, really?
Anyway, thought I'd ask here before heading over to the dealer. Anyone know of a more reasonable source for these screws? Or anyone have the part number or a VW part number as a cross reference?
Thanks
Old Jun 17, 2014 | 08:59 PM
Mad Cow's Avatar
Try another dealer if there's another nearby, I paid around $3-4 per screw. Or get a few with your next online parts order, whenever that happens, and use zipties in the meantime. I don't know the part number off the top of my head, but AFAIK OEM is the only option so the dealership parts guy or ECS would be your best bet. Check the spot where they thread into too, my car was missing a few of the speed nuts or whatever they're called when I bought it, and a couple were so badly rusted that they were useless. They're another $4-5 apiece.
Old Jun 17, 2014 | 10:32 PM
mtroxel's Avatar
2.50 per screw here. But you gotta throw in some oil filters or something like that to make sense of the shipping.
Audi B5 A4 Quattro V6 30v Exterior Body Belly Pan - 8D0805121B - Dowel Pin - Priced Each - ES#2608066
Old Jun 18, 2014 | 12:22 AM
Steve777's Avatar
Thanks guys. Looks like these are available at a much better price than from this dealer online. The local parts store told me there were a dealer only item but not too expensive as they just got some for someone. Looks like they can sell them much cheaper than the dealer will sell them to me for. (This local Audi dealer is known in the area for gouging customers. Makes for quite a few good independent shops)
Looks like there are 3 slightly different "Dowel Pins" like this. One for the front belly pan attachment. Another of slightly different length for the rear center attachment. And yet a third for the outside wheel well attachments. At least that is what I am seeing on the on-line parts diagrams. Can anyone confirm this???
TIA
Old Jun 18, 2014 | 11:01 AM
Mad Cow's Avatar
There's only 2 kinds, my copy of ETKA shows the same part number for all the lower screws, maybe they were different at one point but not anymore. I also just noticed that there's supposed to be a rubber washer between the belly pan and subframe on the 3 rear attachment points, but maybe that's only used if you have the 2nd belly pan under the trans (probably a Euro thing). There's also a lock washer for each wheel well screw, I've done just fine without them but they're cheap so you might as well grab them if they're missing.
Old Jun 18, 2014 | 02:19 PM
mtroxel's Avatar
I know we're beating this to death, but my US spec 99.5 has the rubber washers. I think they are just to hold the blot in the pan when you take it off so you don't lose them.h
Old Jun 18, 2014 | 03:34 PM
Mad Cow's Avatar
That makes sense, I've always found it annoying to have to wedge the belly pan up with my elbow while trying to align it before putting in the bolt.
Old Jun 19, 2014 | 10:21 PM
adam044's Avatar
Mine is held up with only 2 screws I believe and that bracket in the back. Oh and zip tips! You can't see them so who cares.
Old Oct 27, 2024 | 12:23 AM
3dviz's Avatar
If the holes where the belly pan screws in are rusted so that the screws no longer stay in, any ideas on how to fasten the belly pan? Is there some kind of spreader anyone has had success with?
Old Oct 30, 2024 | 01:57 AM
Cybersombosis's Avatar
Are you talking about the 1/4 twist screws? If so the receivers can be replaced with ones from the dealership but they are pretty pricy. You can try the cheapo ones from China on Amazon or AliExpress. If these aren’t the ones you are talking about, then a picture would be great.
