Best Spark Plugs?
Old 02-11-2008, 05:14 PM
aramkim's Avatar
Default Best Spark Plugs?
I'm looking to replace my spark plugs.
What are the best ones to put on my car?
97 audi a4 1.8T Quat.
Guy at autozone suggests NGK.
Should I go with it?
Old 02-11-2008, 05:33 PM
pyropenguin's Avatar
Default RE: Best Spark Plugs?
https://www.audiforums.com/m_329420/tm.htm
NGK BKR6E stock, NGK BKR7E for chipped.
Old 02-11-2008, 05:36 PM
cincyTT's Avatar
I'm make believe
^ The BKR work great and are cheap. Even with frequent changes, they are still cheaper to run than most other higher priced plugs
Old 02-11-2008, 05:38 PM
qUaTtRoA4's Avatar
+1 that's what i run
Old 02-11-2008, 06:58 PM
turbo kraut's Avatar
Tech Guru
i run the coppers and i am tunned..... i had iridiums and it didn't seem to run as good
i think i paid less for 8 coppers than for 4 iridiums
Old 02-11-2008, 07:19 PM
cincyTT's Avatar
I'm make believe
You should be able to get like 16 coppers for the cost of 4 iridiums
Old 02-11-2008, 11:59 PM
aramkim's Avatar
So am I correct in saying that it's not really worth it to get the iridiums?
What's the difference between platinum and copper spark plugs?
Also Bosch sucks right?
Old 02-12-2008, 12:21 AM
Bogie's Avatar
platinum and iridium last longer/more miles than copper. Bosch does not suck; many ofthe parts on your car are manufactured by Bosch.You have a Hitachi (read Japanese) ignition system though, designed to work best with NGK (Japanese) plugs.
Old 02-12-2008, 12:46 AM
chaos92287's Avatar
ORIGINAL: aramkim
no, they make the best copper plug around. the f6dtc
Old 02-12-2008, 01:09 AM
scotts custom's Avatar
wait, so should i get NGK BKR6E, NGK BKR7E. 2 people are saying 2 different things. i run at 16-17 psi, so NGK BKR6E ?
Quick Reply: Best Spark Plugs?
