Blow Off Valve for Audi A4... YAY or NAY?
Old Feb 23, 2007 | 06:46 PM
  #31
swift_A4's Avatar
Default RE: Blow Off Valve for Audi A4... YAY or NAY?
first off, try not to open threads that have been dead for 3 yrs... second you are about to get flamed, but i will let you know that,
audi's have a closed loop system and the car will run very rich if you use a bov. running rich can cause major problems with your cat, you can foul plugs, maf problems, throw codes. go get a DV such as the forge or baileys. if you want that sound a bov makes get an intake, chip and upgraded dv, it is pretty audible.
i am being nice here, try using the search function next time, this topic is covered (unfortunatly) weekly
Old Feb 23, 2007 | 06:47 PM
  #32
BadLuckAudi's Avatar
bah thats to technical for him
ORIGINAL: A4nicator
Ok in a nutshell
DV (diverter valves): "divert" the air back into the intake system hence why they are called Diverter valves
BOV(blow off valves): dump the excess air into the atmosphere.
Now, on an Audi the MAF( mass airflow sensor) is before the diverter valve. Therefore, the air is being hit by the sensor with recycled air and fuel and then determined whether it is running rich or lean, then the valve either puts the fuel/air mix back into the intake or gets rid of it. While, if you install a BOV on this system, the MAF will read the charged air, then be blown out in the atmosphere as a fuel mix, messing with the air fuel ratio on the audi. Essentially, you lose fuel making you car run more rich to compensate. You can buy a Recirculating BOV, but its just a DV with a little more noise. You need that fuel that is being lost by the BOV.
ORIGINAL: 98a4T
i am new with the whole audi think can someone put in dumb terms why a BOV is so bad
Old Feb 23, 2007 | 06:49 PM
  #33
A4nicator's Avatar
LOL I like you definition a lot better its far more "red neck" no pun intended.
ORIGINAL: BadLuckAudi
ORIGINAL: A4nicator
Ok in a nutshell
ORIGINAL: 98a4T
Old Feb 23, 2007 | 11:08 PM
  #34
qUaTtRoA4's Avatar
Yay!...
Old Feb 24, 2007 | 12:41 AM
  #35
A4Rollin's Avatar
HERE IS DUMB TERMS FOR YOU, I CANT STAND SEEING THIS ANYMORE!!!!!!!!!!!!!!!!!!
BOV's AND AUDIEQUALS
IF YOU WANT A BOV SELL YOUR AUDI AND GET ANOTHER CIVIC, thats disrespect brotha...4 rings diserve better
Old Feb 24, 2007 | 12:58 AM
  #36
qUaTtRoA4's Avatar
shady! you posted that audi = Rice, might want to fix that^!!!
Old Feb 24, 2007 | 01:03 AM
  #37
A4Rollin's Avatar
yah the BOV didnt turn up for some reason.....already slapped myself in the face.....four times
Old Feb 24, 2007 | 01:06 AM
  #38
qUaTtRoA4's Avatar
hahaha, it's all good, im sure the noob is more than a little confused right now... *are audi's made in japan?*
Old Feb 24, 2007 | 11:23 PM
  #39
SlimChriz's Avatar
Just though I should chime in and make note of the fact that this is complete gibberish.... did anyone actually read it?
Basically yah the maf is before the diverter valve so the CPU asumes that air that enters Will stay in the line when you let off the throttle andthe engine sucks air past the throttlecreating avacuum and thusly opening the recirculation side of the DV releasing the line pressure.
When you have a BOV all the air exits the line to the atmosphere Causing the car to run rich Because it still thinks said volume of air is in line and it adds fuel accordingly....
That being said there is no air being hit by sensors...Thier is no fuel in the released air because air does NOT flow out of the intake manifold where the injectors are located...
Old Feb 25, 2007 | 12:20 AM
  #40
Lazer Viking's Avatar
thats where it dosent make any sence to me
if there is a setting for how much fuel is added to the amount of air comming in (read by the maf)
then in theory when a bov is added shouldnt the maf read that there is less air comming in and tell the ecu less fuel ?
if not then what the hell is the maf even there for ?
