Boost leak help
Old Aug 9, 2010 | 05:53 PM
HulkB5's Avatar
Im gonna let the car idle to if any oil got in.
Then after a few mins see if it clears.
Old Aug 9, 2010 | 06:03 PM
chocalotstarfish's Avatar
Super Moderator
can you post the diy you followed to do the boost check? I can almost guarantee the diy skipped a step and has now caused oil to feed back into the turbo!
Old Aug 9, 2010 | 06:07 PM
onepoint8tee's Avatar
That sound your heard by the exhuast manifold during the boost leak test is not a boost leak, it's oil in the pcv system getting pushed back into the head- or something like that likely causing the smoke. If you had a boost leak you'd hear it between the turbo and intake manifold. I'm thinking that you don't have a boost leak. Did you upgrade your DV and gap your plugs to .028? If your plugs are at the stock .032, the spark may actauly be getting blown out during high boost.
Old Aug 9, 2010 | 06:08 PM
HulkB5's Avatar
http://audizine.com/forum/showthread...ng-boost-leaks
I let it run the smoke cleared up.
Old Aug 9, 2010 | 06:09 PM
HulkB5's Avatar
I upgraded the DV.
But i did not upgrade the plugs.
So what do you suggest i do with that?
Old Aug 9, 2010 | 06:10 PM
NGK BKR6E - .028
~$2/plug. Start there.
Old Aug 9, 2010 | 06:16 PM
HulkB5's Avatar
Alright thank you so much!!
This is why i love audiforums,
You guys are so helpful.
I'm gonna head up to oriellys in about 2 hours and see if they got them and ill let you know if that solved the issue.
Old Aug 9, 2010 | 06:19 PM
  #18
Super Moderator
YUP, knew it... you are one of many that have gotten screwed by that DIY!
IMPORTANT: In order to perform the pressure test, it is very important that you disconnect the PCV return hose from the TIP. This WAS NOT written in the writeup I was following.....
what happens is that after the system is pressurized, oil comes back down the pcv pipe into the TIP...and hence the turbo....you will end up with blue smoke in your exhaust.....in order to stop this you have to disconnect the check valve for the PCV return line and plug the hole
I used a rubber wine bottle cork and a hose clamp to plug the hole
From the DIY I use!
check out here next time!
https://www.audiforums.com/forum/sho...12#post1225912 make sure you remove the TIP!
Old Aug 9, 2010 | 07:48 PM
  #19
HulkB5's Avatar
ok i just got a spark plug gapper and regap the stock ones because the spark plugs were 7$ a piece and i didn't have enough on me at the time.
Old Aug 9, 2010 | 09:06 PM
  #20
The ungapable bosch +4's came in some B5's fyi.
