Bought this turbo on eBay? Good? Bad? or WTF?!?!
I scour eBay from time to time looking for good deals. I cam across this turbo which is brand new in the box and could not say no since it was a seriously good deal. I could not get enough details from the seller about it to figure out exactly which it is but assumed it was S200 series. Its not. Its definitely not a gas turbo either.
Here is the compressor dimensions:
62mm inducer
87mm exducer
Should put its output range from 300-700hp with ease.
Here is some pictures beside a GT3071R.
I obviously will not be using it since the hotside is 17.5cm but it would be interesting to see it used. I will most likely relist and sell it to a sled puller or maybe a DSM guy.
I converted the cm2 to regular AR and it 1.33 which is not as bad I thought.
62mm inducer
87mm exducer
Looks like it should go on a diesel. Is that a QR code on the tag riveted to the cold side? Can you get a close up of that? Turbine housing aside, you'd have a real hard time getting that compressor housing to work without hitting the passenger's side headlight.
Yeah I don't think it would be the best idea for an A4 but maybe someone else. It has some nice features and size with it being a S362-ish in size and the ported shround comp cover.
It does have one of those funky bar codes but it does not work when you scan it.
Yes 300-700. Thats not peak hp, thats what hp range it can be used on. Its how they are rated.
Its an interesting turbo. I think its way to big for a daily driver unless you have a V6 or the like. Even then it would not be my first choice. On a diesil pickup it would probably be awesome. I am going to sell it as pulling turbo and see what happens. I have another turbo that makes this one look a like baby.
This is kind of funny but not really. I bought both the turbos in the picture and recieved them both today. The Borg was some what a pleasent surprise. However the Garrett beside it I bought to run on my A4. Some problems though. I bought it thinking and was told that it is a GT3071R. Its not. Its a GT3076R with a 7+7 compressor style. This really throws a wrench into things for me.
The GT3071R was going to be the biggest turbo I planned on running. I was told it is 84 trim turbine but its 90 trim. It also has the .86 AR housing. Its in excellent condition as well but I am thinking this thing is just to big for what I am wanting.
On the flip side I could build a 2.0 setup and see how well this would work but I am still thinking this is way too big.
Comments?
Comments?
a 3076 in any variety is a very popular turbo for our cars, albeit a 90 trim with an .86 is a bit big. it would probably make a great drag turbo for high revs, but pretty bad street driving. even with a 2 liter, it ould be too big for street driving in my opinion
as for the BW turbo, that is for sure not a s200. that thing looks more like it belongs on a semi, but if you wanted to run it, bullseye does a ton with BW turbos and im sure they would have an approriate sized housing for that. it looks like a t6 flange. i bet with a t4 dual scroll housing, around 1.10 a/r, you could spool it, but good luck fitting it under the hood. its very difficult to fit dual wastegates in our cars (has been done though), but with a t4 housing? more trouble than its worth. care to share what you paid for it?
I paid just over $200 shipped. Not quite as good a deal as the 3 factory refurbished Garrett t3t4 57 trim carts I got for $210 shipped in my opinion. I didn't buy the borg warner for my audi. Bought it since I knew it was going to be a good deal mostly.
Comments?
Comments?
The one you have is also in a 2871r style compressor housing, they usually came with a 4" inlet housing or with a 2.75" inlet housing. But if you really want to know which it is just measure the compressor wheel inducer/exducer and the turbine wheel inducer/exducer.
If it is a 3076r with the 90 trim exhaust wheel then it is the ATP hybrid setup.
