bumper is pissing me off
Old Mar 30, 2010 | 03:40 AM
joenelson7687's Avatar
Yep...I installed my FMIC and now the passenger side won't clip...FML
Old Mar 30, 2010 | 11:20 AM
Kozzimo55's Avatar
Simple fix everyone. There are only 3 or 4 screws holding that mouning bracket in place. Adjust the way it sits and make sure you are setting the bumper into those side mounts the right way. This is the most common error. Get the bottom to grab first before popping on the top. And a lot of times they bend a little from being improperly removed. Just bend it back and add BJ weld if it's really worn down so the clips don't keep slipping off.
Old Mar 30, 2010 | 11:27 AM
Kozzimo55's Avatar
Old Mar 30, 2010 | 01:58 PM
CCA4's Avatar
yeah i made the mistake of trying to put the top clip in first, would ALWAYS pop off. Clip the bottom in first, then pull up to clip the top in. no screws needed
Old Mar 30, 2010 | 03:32 PM
Tourbo24's Avatar
i had no idea about the bottom, thanks guys i will try it out
Old Mar 30, 2010 | 11:00 PM
jiggleo's Avatar
yeah that always seems to happen. There's a couple of screws in the wheel well that help hold that if your liner is still in good shape.
Old Mar 30, 2010 | 11:04 PM
Calmingstorm's Avatar
Member
Had the same issue, I just put a screw in to stop it. Put the bumper in place, then if you look in the wheel well the plastic fender shield overlaps with the bumper for the thru-bolts, you can put a wood screw thru, out of sight. holds it.
Old Mar 30, 2010 | 11:05 PM
  #18
Tourbo24's Avatar
i think that i am missing the screws in the wheel well. is this why its coming off or is it because i was putting the top on first? lol
Old Mar 30, 2010 | 11:40 PM
  #19
jiggleo's Avatar
yeah def need to put the bottom in first
achTTung
Mar 23, 2008 02:27 PM
klum00
Dec 11, 2007 08:09 PM
mjvss21
Dec 30, 2005 05:06 PM
Slowb5
Dec 7, 2005 11:52 PM
impaler2383
Dec 5, 2005 04:42 PM
