Burning Oil/White Smoke
Old Jan 6, 2009 | 06:43 PM
DÌEGØs AÜD!CTIØN's Avatar
thats weird. my car makes white smoke like when i first start it up (not right away but like 10 sec later) but it goes away. and then it just smokes regular. (which is still white smoke, but not nearly as thick; just.... normal lol)
edit: +1 to what somebody said!
Old Jan 6, 2009 | 08:07 PM
Trey25's Avatar
whats the mileage and does it stutter or misfire? Could be a cam seal, I dunno.
Old Jan 6, 2009 | 08:16 PM
joe11784's Avatar
Member
67k..it doesnt stutter or misfire, it drives fine. i changed the oil like a month ago and its already low. i only drove about 300 miles since the oil change.
Old Jan 6, 2009 | 08:23 PM
Trey25's Avatar
First do a compression test. Could be piston ring(s), pray it's not. Check your pcv valves too. Thats not alot of miles, usually only see that on high mileage motors.
Old Jan 6, 2009 | 09:15 PM
joe11784's Avatar
Member
ok ill try and do a compression test...i just have to get a compression tester lol. before i get that, should i check my pcv valves? and would seafoam help correct this?
Old Jan 6, 2009 | 11:17 PM
merbland's Avatar
I had oil collecting in my FMIC and getting sucked into the intake. It was smoking out the exhaust also, mostly on acceleration from a stoplight. It was fixed by cleaning out the intercooler.
Old Jan 6, 2009 | 11:58 PM
Splinter_Cell's Avatar
Member
Ive basically got the exact same problem that you do joe. the exhaust kinda smells sweet ish, and it burns a bit of oil here and there. but then again i have 172000 miles on mine so im not exactly sure what it is, nor if i want to try and fix it.
Old Jan 7, 2009 | 12:15 AM
  #18
hiwords's Avatar
my car smells of oil when i first start it up. that's because i know i'm burning oil lol. you can get the compression tester from autozone. they have a loan a tool service where you'll get your money back.
Old Jan 7, 2009 | 12:25 AM
  #19
joe11784's Avatar
Member
o ok thanks, i was gonna ask if i could just get that done at a mechanic. it seems easy enough, so ill give that a try n hope its not the piston rings
Old Jan 7, 2009 | 02:48 AM
  #20
Isramirez21's Avatar
Lets hope
Good luck + Keep us posted.
