Buying brakes and stuff. Need to know which items to order?
Hi,
So I just had my brakes checked, it didn't take the mechanic to see I have like 1mm of pad left, but they did say the rotors are pretty much done as well, all 4 wheels. I'm looking at doing A8 front rotors and OEM for rear, then new pads all around. I was told ecstuning.com is a good place to get all this, but I don't actually see a A8 front brake upgrade kit, so can anybody help tell me which items I should order? Do I need the other stuff like brake fluid and a bleeder for this? Also, what pads would you reccommend with this setup (I don't want super performance because I'd rather have no sqeeeeeks, I like quiet) |
RE: Buying brakes and stuff. Need to know which items to order?
purems.com is the place for the cheapest A8 upgrade. As for pads, hawk, pbr, mintex, and ebc all make good street pads all for about $40-60 for fronts and a little cheaper for the rears. there is no need to change fluid unless you want to upgrade the fluid or you have a large amount of miles on the car. You also wont have to bleed them since you wont be disconnecting the lines from the calipers (that is unless you want SS brake lines for a firmer peddle).
so here is what I will order (just making sure I order the right stuff):
312mm front rotors and carriers (B5 upgrade kit). 269$ (should I get ATE + 15$, Zimmerman xdrilled+60$ ??? Or should I spend this extra money on pads?) http://www.purems.com/products/product.php/II=810 ATE rear rotor 245mm. 37$ x2 http://www.purems.com/products/product.php/II=111 PBR rear pads 39$ (will these be loud) http://www.purems.com/products/product.php/II=2061 PBR front pads with sensor 62$ http://www.purems.com/products/product.php/II=2062 So grand total: $444 + shipping/tax |
forgot to mention, audi quoted me 400$ just for the rear rotors alone!!! wow!
the pbr's wont be loud. I rather spend a little more for the zimmermans instead of ate's
you can get hawk hps pads on ebay for like 84 shipped but they are a bit slow. i have the a8 bbk with really crappy pads and they are well beyond my expectations, i would suggest fluid and steel lines too but if you're tight on money get them later.
ORIGINAL: dr_zoidberg so here is what I will order (just making sure I order the right stuff): EDIT Zimmerman xdrilled 312mm front rotors and carriers (B5 upgrade kit). 329$ http://www.purems.com/products/product.php/II=810 EDIT Zimmerman rear rotor 245mm 36$ (on sale for less then ATE anyways) http://www.purems.com/products/product.php/II=610 PBR rear pads 39$ (will these be loud) http://www.purems.com/products/product.php/II=2061 PBR front pads with sensor 62$ http://www.purems.com/products/product.php/II=2062 So grand total: $502 + shipping/tax also, cincytt, check out that top 10 posters list :) soooo close |
ORIGINAL: hiwords you can get hawk hps pads on ebay for like 84 shipped but they are a bit slow. i have the a8 bbk with really crappy pads and they are well beyond my expectations, i would suggest fluid and steel lines too but if you're tight on money get them later. |
