Buying brakes and stuff. Need to know which items to order?
Hi,
So I just had my brakes checked, it didn't take the mechanic to see I have like 1mm of pad left, but they did say the rotors are pretty much done as well, all 4 wheels.
I'm looking at doing A8 front rotors and OEM for rear, then new pads all around. I was told ecstuning.com is a good place to get all this, but I don't actually see a A8 front brake upgrade kit, so can anybody help tell me which items I should order? Do I need the other stuff like brake fluid and a bleeder for this? Also, what pads would you reccommend with this setup (I don't want super performance because I'd rather have no sqeeeeeks, I like quiet)
purems.com is the place for the cheapest A8 upgrade. As for pads, hawk, pbr, mintex, and ebc all make good street pads all for about $40-60 for fronts and a little cheaper for the rears. there is no need to change fluid unless you want to upgrade the fluid or you have a large amount of miles on the car. You also wont have to bleed them since you wont be disconnecting the lines from the calipers (that is unless you want SS brake lines for a firmer peddle).
so here is what I will order (just making sure I order the right stuff):
312mm front rotors and carriers (B5 upgrade kit). 269$ (should I get ATE + 15$, Zimmerman xdrilled+60$ ??? Or should I spend this extra money on pads?)
http://www.purems.com/products/product.php/II=810
ATE rear rotor 245mm. 37$ x2
http://www.purems.com/products/product.php/II=111
PBR rear pads 39$ (will these be loud)
http://www.purems.com/products/product.php/II=2061
PBR front pads with sensor 62$
http://www.purems.com/products/product.php/II=2062
So grand total: $444 + shipping/tax
you can get hawk hps pads on ebay for like 84 shipped but they are a bit slow. i have the a8 bbk with really crappy pads and they are well beyond my expectations, i would suggest fluid and steel lines too but if you're tight on money get them later.
ORIGINAL: dr_zoidberg
EDIT
Zimmerman xdrilled 312mm front rotors and carriers (B5 upgrade kit). 329$
EDIT
Zimmerman rear rotor 245mm 36$ (on sale for less then ATE anyways)
http://www.purems.com/products/product.php/II=610
So grand total: $502 + shipping/tax
EDIT
EDIT
also, cincytt, check out that top 10 posters list
soooo close
ORIGINAL: hiwords
Autophile62mmB5
Feb 11, 2011 08:30 PM
