Cam alignment off?
Old May 30, 2009 | 12:35 AM
redline's Avatar
Default Cam alignment off?
I am replacing the timing belt on my 2.8. When I went to put the cam locking tool on, I discovered that it didn't quite fit in both cam gears correctly. The crank is definitely in the correct position and is locked with the tool. The cams are also correctly oriented (larger washer holes towards each other). The passenger side cam is turned very slightly counter-clockwise from dead horizontal (from the washers perspective), preventing the tool from locking both sides together. Is it ok to move it into alignment with the other cam?
Old May 30, 2009 | 12:05 PM
nhill2090's Avatar
No do not disrupt the timing.
Any ways, is the fan clutch reverse threaded? I'm doin a timing belt on my 2.8 right now and am trying to get the fan clutch and pulley off.
Old May 30, 2009 | 04:39 PM
redline's Avatar
Yes, it is reverse threaded.
Old May 30, 2009 | 11:20 PM
nhill2090's Avatar
I found that out, thanks.
Did you ever come to a solution for your problem?
Oh, and when you set the tension on the timing belt, you pull the pin and let the hyrdaulic arm loose and then preset the tensioner to 15NM with a torque wrench correct?
Old May 30, 2009 | 11:43 PM
auditech79's Avatar
Just use the cam bar to crank over the cam so the bar fits on there, they sometimes move a little bit.
Old May 30, 2009 | 11:51 PM
Midniteoyl's Avatar
Agreed.. use the tool to align the cams, not the old belt
Old May 31, 2009 | 02:03 PM
redline's Avatar
Thanks auditech and midniteoyl, thats what I thought. I also went ahead and pulled the valve covers and verified that the cams alignment marks are matched up and at TDC.
kevintt
Jun 21, 2008 05:25 PM
kwaskow
May 23, 2008 06:08 PM
grrrrrrr
May 9, 2008 07:41 PM
wings7351
May 24, 2007 01:42 PM
ouTTie914
Aug 17, 2006 10:48 PM
