Camshaft and Crankshaft Seal for Timing Belt change.....???
Old Dec 9, 2010 | 02:15 PM
Aud1A4's Avatar
Question Camshaft and Crankshaft Seal for Timing Belt change.....???
While studying and going over the DIY guides for changing the timing belts, they never mention anything about changing the camshaft and crankshaft seal and I see them in a kit Im about to order......
Are those necessary to change and how would I go about changing them?
Old Dec 10, 2010 | 07:11 PM
Aud1A4's Avatar
bumpy bumpyyy. does anybody know?
Old Dec 10, 2010 | 07:24 PM
Andrew149's Avatar
most people dont replace them because to get them out you might scratch the metal and ruin the seal but you can do it if to want to do it just be very careful and i also like to use some mr.gasket around the gaskets to make sure its sealed up nicly =D
Old Dec 11, 2010 | 12:37 AM
Dallas09's Avatar
I replaced them on mine, I couldnt find much about it either, my neighbor helped me. We basically gouged out the old ones by bending them and prying them out, then put the new ones in by tapping them in evenly with a very large socket.
Old Dec 11, 2010 | 01:04 AM
FASTER's Avatar
Tech Slut
Ever heard the phrase, "if it ain't broke, don't fix it?"
Old Dec 11, 2010 | 02:43 AM
A4 2000's Avatar
I have an oil leak coming from behind the TB cover and I'm assuming it's from one of those seals. SUPPOSEDLY, new seals were installed when I had my engine swap, but maybe they weren't placed in there correctly or the mechanic damaged the seats. They were from the Blauparts full timing belt kit. I guess I won't find out for another year when it's time to change the TB again.
Old Dec 14, 2010 | 09:03 PM
Aud1A4's Avatar
http://www.youtube.com/watch?v=M_VQHvqXaYU
check out that video to properly change the cranshaft seals
so it looks like i wont be changing them and i rather not gouge them out so if nothing is leaking i wont change them
Old Dec 14, 2010 | 09:52 PM
dragonrage's Avatar
I had a kind of crappy time getting mine to seal even though I could have sworn I was installing them right.
KEVBASA6
Oct 14, 2013 07:18 PM
BesI
Aug 20, 2011 01:13 AM
Dallas09
May 18, 2010 02:40 AM
vtraudt
Mar 11, 2010 09:06 PM
