Can this clear the lights in the center lcd?
Old Dec 26, 2011 | 09:41 PM
pbrules10's Avatar
Default Can this clear the lights in the center lcd?
Audi B5 A4 Quattro 1.8T > Engine > Tools > ES#9951 V-Checker Scanner - Basic - VAGCHECKERBASIC
I have random lights in the center driver lcd screen and was wondering if this could clear them? What else can this do besides read codes, is it worth it?
Old Dec 26, 2011 | 10:24 PM
turbo kraut's Avatar
Tech Guru
That won't do anything for the center lights. It's for your cel/mil
Old Dec 27, 2011 | 12:34 AM
BaconBait's Avatar
The codes will come back until you fix the problems.
Disconnecting the battery for 30 min will clear the codes. Make sure you have your radio code before you do that. One they're cleared, head to autozone and have the codes checked and post them here.
Old Dec 27, 2011 | 09:20 AM
CCA4's Avatar
What lights are you seeing in the center LCD screen? Usually those are important...
Old Dec 27, 2011 | 09:43 AM
chocalotstarfish's Avatar
Super Moderator
Yeah that means you need to fix something. LCD stuff sows you when you brake pads are low and lights out ect you can't clear those they go away when you fix the problem. But if you want an out of site out of mind approach use some black tape to cover it
Old Dec 27, 2011 | 10:14 AM
TaConklin's Avatar
Reverse that. Codes can't be checked unless they're there. If he clears them and goes to Autozone or wherever nothing will happen because there will be no codes to check.
Old Dec 27, 2011 | 10:38 AM
Super Moderator
What he ment was clear the codes drive around to see which once come back then go get them scanned to see what needs fixed.
Old Dec 27, 2011 | 04:30 PM
TaConklin's Avatar
Ahh, gotcha.
Old Dec 27, 2011 | 06:09 PM
Tech Guru
But as I stated first and others state. A scan tool won't fix/help fix the LCD "codes"
Old Dec 27, 2011 | 06:21 PM
jonbonesjones's Avatar
Moderator
they are easy problems to fix in the center lcd. like washer resivor empty, brake light out, oil temp. the normal stuff you should see that it gets fixed
