This can not be good!!!....pulled these codes
Old Jul 8, 2008 | 02:23 AM
JCatt9's Avatar
Default This can not be good!!!....pulled these codes
Hi guys,
My car is a 2000 a4 1.8t quattro and currently is sitting at 180,000 kms. I was driving it recently when all of a sudden it started to hesitate pretty bad and almost stall out, I pulled over to the side of the road and noticed a slight knocking sound so I shut her down and had it towed to a dealership. They think it is a can tensioner that has given out, but couldn't pull the codes till i disconnected my aftermarket cd player........
Here are the codes I pulled:
16687-misfire cyl #3
16688-misfire cyl#4
16685-misfire cyl#1
16686-misfire cyl#2
16684-misfire any cyl
18010-power supply low
17522(?)......my code book doesnt even show this :S
Any idea on what could be the cause of this and really how bad is it?
Thanks, JC
Old Jul 8, 2008 | 02:40 AM
Audi_Skydiver's Avatar
Default RE: This can not be good!!!....pulled these codes
When was the last time you chaned your spark plugs?
Josh
Old Jul 8, 2008 | 09:51 AM
rsrbljan's Avatar
Looks to me like low voltage running into the coilpacks resulting in misfires... Also could be a grounding issue? I'd do plugs, and reseat all the electrical connectors.Clean the contact points on any electrical junctions at the coil packs and clear the codes and check again... That's where I'd START.
Hope it gets you rolling in the riht direction,
Ryan
Old Jul 8, 2008 | 12:12 PM
JCatt9's Avatar
I haven't changed te plgs since I purchased it at 150,000 kms, I'll pass on the info to the dealership.....thanks guys
99A4BlackNGrey
Jan 19, 2009 10:59 PM
audi_n00b
Jan 8, 2009 10:40 PM
socalaudi
Jan 8, 2008 11:56 AM
qttrcoupe
Oct 26, 2007 04:36 PM
bmwtoaudi
Feb 22, 2007 11:18 AM
