car wont go above 4000rpm
Old 08-06-2008, 08:52 PM
BOOSTME's Avatar
Default car wont go above 4000rpm
i have an a4 1.8t tip and ever since i got the car it has never reved past at most 4200 even in tip mode. now i don't know whether this is just because it is an auto trans and it has a limiter or if something is wrong with the trans i already scanned the trans and came up w/ no codes
Old 08-06-2008, 09:18 PM
ghost6303's Avatar
well um... what happens when you try?
Old 08-07-2008, 07:16 PM
BOOSTME's Avatar
what do you mean?
Old 08-07-2008, 07:26 PM
Leifer's Avatar
Take it to 5th gear then try flooring it past 4k and see what happens.
Did you scan the engine for fault codes? I believe, in tiptronic cars, there's a separate diagnostics for anything transmission-related. I could be wrong though.
Old 08-07-2008, 07:30 PM
onepoint8tee's Avatar
What happens if you floor it in D? Are the shift points for every gear at 4200 rpms? If you hold 1st gear in tip, what happens at/after 4200 rpms? Is it upshifting automatically in tip mode before reaching redline?
Old 08-07-2008, 08:07 PM
BOOSTME's Avatar
it does exactly that in drive and in tip. so no matter what mode im in it will shift at around 4200 at most
Old 08-07-2008, 09:30 PM
Leifer's Avatar
Try it in 5th?
Old 08-07-2008, 09:34 PM
BOOSTME's Avatar
i would try it in 5th but i don't need more tickets
Old 08-07-2008, 09:35 PM
Leifer's Avatar
Freeway onramp? Good time to test your tires out, too
Edit: I'm just kidding. I'd try it anyways on a stretch of freeway where there's usually no cops, just get up and go for it. It's not even going that fast, 4k in 5th?
Old 08-07-2008, 09:39 PM
BOOSTME's Avatar
ya but im usually still in third by the time i hit the actual freeway i would have to top out the car to reach 4 grand in 5th
Quick Reply: car wont go above 4000rpm
