car wont move help! is it the clutch?
Old Oct 27, 2009 | 12:08 PM
hatinyet's Avatar
Default car wont move help! is it the clutch?
i have a 1.8t 5 speed. i was driving in 3rd gear all of a sudden when i went to accelerate it didnt, so i switched gears and nothing happened i then pulled over and tried to launch the car in every gear including reverse but it wont move just revs. the other thing thats happening is that i can put the car in any gear without having to use the clutch and it wont stall the car isnt making any noises at all... someone please help me
Old Oct 27, 2009 | 12:15 PM
hiwords's Avatar
one or more of your axles have popped out of it's seat. you gotta put it back in and tighten it up. stop trying to drive your car or you will kill the clutch
Old Oct 27, 2009 | 12:17 PM
airguard350's Avatar
Tech Guru
^ x eleventy-seven million
Old Oct 27, 2009 | 12:24 PM
hatinyet's Avatar
i havent tried to drive it but if it was the axle would the car go into gear without the pressing of the clutch without grinding or some kind of noise?
Old Oct 27, 2009 | 12:28 PM
bradtyler02's Avatar
maybe, maybe not. If the axel isn't turning the wheels, then there is no load on the drive train allowing it to engage with minimal effort... all the power is going to the wheel with the least resistance, being the one that spins freely...
Old Oct 27, 2009 | 12:32 PM
hiwords's Avatar
so the car is on and you can put it in gear without stepping on the clutch? you have some serious problems. does you pedal feel different? if not i think you have just busted the tranny. and for you to bust an audi 5 speed tranny, you have been awarded the armour peircing bullet award because those trannies only really go bad if you have a builted engine and you race with it. good thing these trannies can be found all over so make sure you get the right tranny code from yours and match it up with another one from somebody else's
hatinyet's Avatar
could the clutch cause this as well? is there an easy way to tell if its the axle or the clutch?
Old Oct 27, 2009 | 12:35 PM
hatinyet's Avatar
if it was the tranny wouldnt it make noise and i was at low rpms when this issue occured..the car is pretty much acting as if i had the clutch pedal pressed down even when i dont if that helps
Old Oct 27, 2009 | 12:40 PM
hiwords's Avatar
right i understand what you're saying. that's why i asked if the pedal felt different. does the shifter feel different too? if it was the axle, your car would try to move forward when you engage the clutch but it won't move. if you can put the car into gear when it's on without touching the clutch pedal, your problem is pretty serious. also it sounds like your clutch is disengaged all the time. pm auditech79 if you want an answer from a real tech. he's the best. good luck man
Old Oct 27, 2009 | 12:45 PM
hatinyet's Avatar
yea but if the clutch is just staying disengaged wouldnt that be just clutch or pressure plate related not tranny
