CEL came on last night
Old Mar 19, 2008 | 10:05 AM
flyromeo3's Avatar
Default CEL came on last night
I havent ran the code(s) yet but I suspect it may be bad gas. I filled up the car and drove about 15-20 miles. A couple blocks from my house I stopped at a red light and could hear some slight sputtering from the muffler. ( it didnt sound right ) eventually CEL came on but i continued to drive. About two blocks later I stopped hearing the sputter and the car sounds perfect. Runs fine, no jerking, no loss of acceleration but the darn thing is still on.
I recall in my honda I used to be able to disconnect the battery for a few minutes which resets the ECU but, after searching last night on this forum it looks like that method wont work for Audi's.
Also, you could use a paper clip and jump two pins on the OBD port which flashes a light on the dash and the aount of flashes represents the DTC code causing the CEL. Does this work with Audi?
Anyone have an idea what may of caused this CEL? ( im going to go to autozone this afternoon to have them read it )
I suspect bad gas but, the car seems to be running fine as it was prior to the CEL appearing.
advanced thanks btw.
99 2.8Q
Old Mar 19, 2008 | 10:31 AM
CRAZYHAWK's Avatar
Default RE: CEL came on last night
Buy a code reader.
http://search.ebay.com/search/search...&category0=
Old Mar 19, 2008 | 10:58 AM
flyromeo3's Avatar
Thanks for the suggestion but I was hoping someone may of experienced the same thing and could possibly direct me to what their resolution was.
I'm going to order the reader but Im anticipating it wont be delivered before friday since im driving west this weekend ( about 70miles )
Old Mar 19, 2008 | 11:34 AM
tdn's Avatar
tdn
Disconnecting the battery will get rid of the cell, but make sure you have your radio code, you'll have to enter it in to get your stock radio to work.
Just get the code read, and do a search for the code. If nothing pops up during the search (i doubt it) post the code here.
Where in the north east are you located?
edit: by the way, when/if you disconnect your battery, leave it disconnected for 10-15 minutes.
Old Mar 19, 2008 | 12:03 PM
less_of_me's Avatar
Just go to Autozone. Have them clear the code when you are done. As you probably know, Autozone will tell you what the code is and to be safe, you can just post it here on the forum and somebody will most likely know what it is too. Sorry, but I have never put bad gas in my car, so I don't know if that is what the problem is for you.
Old Mar 19, 2008 | 12:19 PM
flyromeo3's Avatar
im in queens NY.
hmmm,...I remember changing my headlight switch and I had the battery disconnected for almost an hour and upon reconnecting the radio never asked for a code.
I have the stock tape deck ( which surprisingly sucks ) so maybe the designers thought why put a code if no one wants a tape deck radio.
imma disconnect the battery for a bit and see if it resets it. If it returns i'll go to autozone. Actually if its free i'll go to them first.
Old Mar 19, 2008 | 12:42 PM
less_of_me's Avatar
Autozone is definitly free. Some times they ask me to put a desposit in, but then it gets refunded so no biggie. Also...I have had the battery disconnected for hours on end and never needed the radio code either. But I always only disconnect the 'hot' side and leave the ground. Maybe that has something to do with it.
Old Mar 19, 2008 | 01:10 PM
tdn's Avatar
tdn
flyromeo, noticed you have a pre face lift a4, disregard what I said about the radio as thats only for 99.5+ a4's.
Old Mar 19, 2008 | 02:07 PM
flyromeo3's Avatar
thanks guys. Ill let you know what i discover later on
Old Mar 19, 2008 | 06:38 PM
flyromeo3's Avatar
long story short i bumped into an old friend that was working on his car in his garage. He has a OBD reader and pulled this code
P0306
Cylinder 6 misfire.
I havent spoken to my brother yet to find out when he last did a tune up on the car. I know I havent changed anything since buying it from him in december.
