CEL Codes.
Old Feb 3, 2008 | 09:43 PM
pyoung9's Avatar
Default CEL Codes.
P1408
P1504
P0401
1996 A4
This is what I found online...
0401 - Exhaust Gas Recirc.Flow Insufficient Detected
1408 - EGR Temp.Sensor Signal too High
1504 - Intake Air Sys.Bypass Leak Detected
Do I need to take this in to get fixed? Can I do it myself... I'm completely lost.
Old Feb 3, 2008 | 10:19 PM
pyoung9's Avatar
Default RE: CEL Codes.
And would any of these codes be causing horrible gas mileage? I'm getting 16MPG right now of 65/35 hiway to city driving
Old Feb 3, 2008 | 11:31 PM
pyoung9's Avatar
I know triple post... This is what I found online...
Old Feb 4, 2008 | 02:08 PM
pyoung9's Avatar
Bump please?
Old Feb 4, 2008 | 03:10 PM
CoastalA4's Avatar
The first two codes are most likely related. Chech your EGR with a vacuum pump for movement. Ok, then check EGR piping or clogged EGR port.
Third code is for either the Idle Air Control valve or a leak in the intake plumbing.
Old Feb 4, 2008 | 05:08 PM
pyoung9's Avatar
Would any of these be causing bad gas mileage? Are they expensive fixes? Can I fix it myself?
Old Feb 4, 2008 | 09:45 PM
tdn's Avatar
tdn
I did some searching, all I find that might help you is this http://www.engine-light-help.com/egr-valve.html
The codes are definitely related to your gas problem from what i'm reading. Good luck, hopefully someone had a similar problem and can help you out. Otherwise try some other forums, someones bound to give you some direction.
Old Feb 7, 2008 | 12:10 AM
pyoung9's Avatar
Anyone else?
Old Feb 7, 2008 | 09:26 AM
CRAZYHAWK's Avatar
Do a search for "Seafoam".
Old Feb 7, 2008 | 07:05 PM
pyoung9's Avatar
K
