cel help
Old Mar 1, 2009 | 03:30 PM
audinewbie88's Avatar
Default cel help
whats up guys.. ive got a 1996 2.8 and i just coded it and it had one code it was P1407 EGR Temp.Sensor Signal too Low...
this just simple as replacing the coolant temp sensor?
thanks in advance guys
Old Mar 1, 2009 | 06:34 PM
akielb's Avatar
not a valid code, but I would say just replace the CTS
http://www.audiworld.com/tech/eng54.shtml
Old Mar 2, 2009 | 04:36 PM
Old Mar 3, 2009 | 12:37 AM
Tweaked's Avatar
EGR (Exhaust Gas Recirculation) is NOT ECT (Engine Coolant Temperature). EGR refers to the EGR valve, AKA the combi-valve, kombi-valve, or secondary air injection valve. It has nothing to do with the ECT sensor.
That code is telling you the valve or lines to the valve are likely clogged.
