CEL P0302 97 a4 1.8t NOT ICM UNIT.
Old 04-30-2013, 08:01 PM
thefuture54's Avatar
Unhappy CEL P0302 97 a4 1.8t NOT ICM UNIT.
I have a 97 a4 1.8t. Last year I was having random misfirings, while the car was shaking violently. Replaced the ICM. Problem solved. This year, car was shaking violently again, but this time only p0302. I had spare coils so I replaced all of them. Problem not solved. I then thought maybe the ICM was bad again. I replaced it with one from a local auto parts store. Problem not solved. Then thought maybe the replacement was bad, so I bought another ICM from a different store. Still not solved. Everything I read for p0302 is ICM, ICM ICM. But I am thinking either spark plugs, igniters, or wiring. Please help!
Old 05-01-2013, 02:43 AM
CryptoStorm's Avatar
The very first thing I would have done is plugs.. Bosch double platinums..
That code is cylinder 2 - the middle cylinder on the passenger side..
Is it misfiring all the time?
Old 05-01-2013, 08:44 AM
Yes. It is misfiring all the time.
Old 05-01-2013, 09:18 AM
If you haven't changed your plugs then you should.. They're the first thing any shop is going to replace when a missfire is detected. Plus they should be replaced every 40-70k anyway as they become worn and cause the gap to get larger..
Old 05-01-2013, 09:21 AM
I forgot.. IDK how long you've had the car, but these cars are fairly picky about plugs.. I recommend the bosch double plats. If you get them DO NOT try and gap them.. They are pre-gapped and you will ruin the plug by trying.
Old 05-05-2013, 06:48 PM
CryptoStorm thank you for all your help. Unfortunately after replacing the plugs, coils and ICM, I am still getting the CEL p0302. Any other thoughts?
jcA4Quattro
05-03-2023 01:55 PM
dufftime
04-07-2017 02:09 PM
n_gunjan
09-23-2013 11:42 AM
thefuture54
05-09-2013 10:23 PM
catdog
02-11-2008 10:27 AM
Quick Reply: CEL P0302 97 a4 1.8t NOT ICM UNIT.
