central locking
Old Jul 4, 2014 | 12:07 PM
patc's Avatar
Default central locking
Hi all hope someone can help. ive changed my centrol locking pump and now my key fob dont work. i can lock it with key, ive changed batteries in fob and followed instructions but nothing
Old Jul 4, 2014 | 08:35 PM
bradtyler02's Avatar
If you changed out the whole assembly, you will probably need to reprogram the fob itself with VAG-COM or at a dealer.
Old Jul 5, 2014 | 11:41 AM
A4TurboGuy's Avatar
I'm about to change mine out today or tomorrow.
Are you sure this is going to be necessary?
Old Jul 5, 2014 | 12:35 PM
I'm about 90% sure. I'm pretty sure this has been covered in a few threads. A focused search in the B5 sub forum should find the exact answer you're looking for.
If you simply replaced just the pump itself, and left the electronics in place, the fob should re-sync on it's own after a day or two.
Old Jul 5, 2014 | 12:41 PM
patc's Avatar
Been to audi. no luck. got them stumped. there saying i need a new remote £100+ vat, im not giving up. going to have a play with electrics myself, who knows. might fix it
Old Jul 6, 2014 | 11:38 AM
A4TurboGuy's Avatar
Unfortunately, my problem isn't the pump. It's the RF receiver.
I was driving like an ******* in the deep *** waters of a Florida "surprise" thunderstorm, w/o knowing that Audi put the CLU in the worst possible spot ever.
Now I'm about to find out whether or not a different one will work (assuming I bought a legit-working replacement).
I'll keep you guys posted, as I'll be doing it today.
Old Jul 6, 2014 | 12:51 PM
A4TurboGuy's Avatar
No luck.
Will a registered version of VCDS Lite be able to do it?
Old Jul 6, 2014 | 02:41 PM
A4TurboGuy's Avatar
UPDATE:
You can accomplish this with VCDS Lite (free).
I just did mine and after lots of burned out brain cells, I've got it working great.
D/L VCDS Lite here: Ross-Tech: VCDS-Lite: Download
Check #35 Here: Ross-Tech: VAG-COM: Audi B5 VAG-COM Info
This is the procedure for VIN code "8D" (my car), but they have all models also:
Audi A4 (8D) Central Locking - Ross-Tech Wiki
Good Luck w/everything. Let me know if I can help further.
Old Jul 7, 2014 | 07:14 AM
Glad that worked out for you!
Old Jul 7, 2014 | 06:29 PM
elduderino200's Avatar
What was the procedure attempted for the re-sync? I can't remember exactly how I did mine but I know you need two keys (one can be a cheap valet key). One then is left in the ignition with the power on but not the engine, the other is used to manually lock the driver door. That should sync it up.
At least I think that's it. Try locking and unlocking it a few times manually. Then the FOB should work.
I should clarify: The key you need to re-sync is the one doing the manual locking. Either a working fob or a valet key is the one left in the ignition.
