central locking
Old Jul 8, 2014 | 06:41 AM
bradtyler02's Avatar
I'm pretty sure after a day of two of manually locking and unlocking as needed, it will re-sync on it's own. I'm pretty sure that's how mine worked whenever I would have to disconnect the battery (or when I fixed my locking pump). Again, the transponder thing in the trunk remained the same, I just fixed the pump itself.
Old Jul 8, 2014 | 10:17 AM
A4TurboGuy's Avatar
Originally Posted by elduderino200
What was the procedure attempted for the re-sync? I can't remember exactly how I did mine but I know you need two keys (one can be a cheap valet key). One then is left in the ignition with the power on but not the engine, the other is used to manually lock the driver door. That should sync it up.
At least I think that's it. Try locking and unlocking it a few times manually. Then the FOB should work.
I should clarify: The key you need to re-sync is the one doing the manual locking. Either a working fob or a valet key is the one left in the ignition.
I believe the instructions are in one of the links I posted, but the good key/FOB goes in the ignition. Turn car to "on" position. Check VCDS for the existing key number/position. Manually lock the door with the bad FOB, them - within 5 seconds, press the unlock button on the new/bad FOB enough times to put you one number past the VCDS number, then wait 5 seconds and hit the unlock button again. It should then work.
This didn't work for me personally.
a3turrell
Jun 4, 2023 11:15 PM
leonwolves
Aug 30, 2011 02:34 PM
Mikkke
Aug 26, 2010 01:52 PM
hazz37
Oct 30, 2006 01:51 PM
del_piero_3
May 5, 2005 08:16 AM
