changing driver low beam headlight
I cannot seem to figure out how to change my low beam headlight on the driver side. I unscrew the two hex screws at the top and I don't know what to do next. Any suggestions??????
You shouldnt have to take the whole housing/headlight out to change the bulb. But to answer your question, there is a 3rd torx screw down on the side. You might need a flashlight to see it.
Just unclip the back cover of the healight, take it off, remove the wiring plug to the bulb, unclip the wire that holds the bulb in, remove bulb.
depends what year you have. 2 piece headlights have 4 screws, 1 piece have 3. i show how to remove it in my forge dv/bov DIY https://www.audiforums.com/m_732016/tm.htm
Debeli
Jul 4, 2012 12:21 PM
