Check Engine Light: Error Code
Old Jun 16, 2008 | 08:06 PM
smoovmusicdj's Avatar
Default Check Engine Light: Error Code
Hello,
My check engine light came on today and I went to AutoZone and I got the following reading: PO411/secondary air inj sys incorrect flow. I was just wondering if anyone knew what this is. I noticed that my car has been driving a little bit rough and that it idles a little bit worse. Basically, it feels like the transmission is missing or hesitating. Would this cause it? And also the INSP indicator came on at the same time. Please let me know if you know what the problem is and also the cost. THANKS EVERYONE!
Old Jun 16, 2008 | 09:31 PM
lawnferie's Avatar
Default RE: Check Engine Light: Error Code
I know that the INSP indicator comes on normally after certain mileage, that can easily turned off. As for the timing that it happened at the same time... That's a different story.[&:]
Old Jun 16, 2008 | 09:51 PM
acollicott's Avatar
https://www.audiforums.com/m_515068/tm.htm
perkykid
May 19, 2015 10:48 PM
Untouchabl3
Jun 6, 2011 02:33 AM
smoovmusicdj
Jun 16, 2008 08:06 PM
gordond
May 11, 2007 05:11 PM
