Check engine light with no codes?
Old Feb 13, 2010 | 01:28 PM
mowoc's Avatar
Default Check engine light with no codes?
Greetings,
I am pretty new to Audi's, so please forgive my ignorance.
I have a check engine light on an 2000 A4 1.8 AWD vehicle. I plug in the OBD scanner and get nothing - no codes at all yet the check engine light will not go out. Does anyone have any idea where to start or what I should do next?
I am very sure the codes were not erased as I was the only one to mess with this.
Thanks for any and all help.
dragonrage's Avatar
Use VAG-Com because it can scan more systems in the car than a normal OBD scanner.
Old Feb 13, 2010 | 01:36 PM
mowoc's Avatar
Wow, $500 for scanner seems like quite a bit. Forgive the ignorance, but what does VAG COM do that a normal OBD scanner does not?
I am really interested in finding out the codes it is throwing today if possible. Any other thoughts on how I might obtain the codes somehow today?
Old Feb 13, 2010 | 01:37 PM
dragonrage's Avatar
http://www.alpha-bid.com/vagusb.html is what you need. For why to use VAG-Com, search.
Old Feb 13, 2010 | 01:52 PM
Tourbo24's Avatar
just go to autozone or pepboys and get it scanned for free
Old Feb 13, 2010 | 05:52 PM
mowoc's Avatar
I did actually go to AZ. Their scanner must be better than mine - it came back with P0411.
Based on my reading that could be anything from a vacuum hose to a secondary air pump.
I would appreciate any pointers on how to test this situation.
RedA4guy
Mar 15, 2014 08:59 PM
rb12
Apr 27, 2010 01:14 AM
TimmyTT
May 18, 2008 10:08 PM
Mattchef
Sep 7, 2007 06:10 PM
