Check Engine says: System Running to Lean
Old Sep 15, 2010 | 09:34 PM
Rickypr's Avatar
Default Check Engine says: System Running to Lean
Check Engine says: System Running to Lean.....what could it be??
Old Sep 16, 2010 | 11:41 AM
Gill248's Avatar
I had the same problem. i had a code for engine running too lean but there was no misifres or rough running. it was the Mass Air Sensor. I replaced it first after checking all the vacuum lines and it has not come back.
Old Sep 17, 2010 | 12:31 AM
Dallas09's Avatar
Most common problem is a vac leak. The line that goes from the front part of the intake mani to the diverter valve, and the line that goes from the fuel pressure regulator to the intake mani often become brittle and break.
Old Sep 20, 2010 | 03:16 PM
Chewster's Avatar
OK I have this same problem... What are these vacum lines called and where can you get replacements i know mine leaks just cant find anyone with them
Old Sep 20, 2010 | 03:19 PM
Dallas09's Avatar
Most refer to them as vacuum hoses... most auto part stores have reels of them and you can cut as much as you want. Otherwise heres this: http://www.ecstuning.com/Search/Vacuum_Line/ES1928259/
Old Sep 21, 2010 | 12:51 AM
joenelson7687's Avatar
+1 good stuff from ecstuning. I've fouond that the hose you get at parts stores isn't as "thick" as the ecs line...
mazzman912
Dec 16, 2019 03:28 PM
Jeff_Brown
Jan 6, 2014 10:13 AM
Cesar333
Jun 16, 2010 09:12 AM
fatcatA4
May 23, 2008 01:03 PM
TurboManiacal
May 4, 2006 06:00 PM
