Clutch Pedal vibration and noise
Old Dec 21, 2009 | 09:57 PM
quiktsi's Avatar
Default Clutch Pedal vibration and noise
Ok first off this is a b5 1.8t. The car has 128k on it. I was just driving along and suddenly a vibration in the clutch pedal when I depress the clutch to up shift. Also when I take off from a stop there is a chattering noise. While driving it seems fine. I do notice a slight noise at lower rpms like when im slowing down to come to a stop while in gear. I was thinking a bad throw out bearing but then I noticed while clutch pedal to the floor i can gas it and it will make 1 chatter and then nothing. Any input would be greatly appreciated.
Old Dec 22, 2009 | 10:11 AM
Mike-2ptzero's Avatar
Sounds like it could be a bad dual mass flywheel since you only have the issue when there is no or very little load on the flywheel/clutch.
mhitchcock139
Oct 15, 2013 09:56 AM
kenbonedoc
B8 Models
Sep 13, 2011 07:52 AM
funstuffalex
Apr 10, 2010 10:30 AM
Tuppidsay
Mar 12, 2010 09:44 PM
jkucz28
Oct 21, 2006 08:49 PM
