AudiForums.com
-   B5 Models (https://www.audiforums.com/forum/b5-models-69/)
-   -   Codes, Codes, and more Codes...and no boost (https://www.audiforums.com/forum/b5-models-69/codes-codes-more-codes-no-boost-155111/)
joenelson7687 Aug 18, 2010 09:07 PM
So its gotta be an internal leak then...gotcha. I'll post back when I get the little mother f'er off. Hopefully I won't get fagged up the ass and thats all that's wrong with it is a $50 wastegate!
onepoint8tee Aug 18, 2010 09:15 PM
you have a tune for this k04 right? Or at least a k03 chip? An external leak of stock 8-10psi wouldn't be as audible and would be much easier to lose before the manifold compared to a ~18-20 psi k04 or k03 tune.
joenelson7687 Aug 18, 2010 09:52 PM
I have a Turbosmart Tee MBC and the cincy diode mod. I push around 16psi depending on how hot it is.
onepoint8tee Aug 18, 2010 10:03 PM
If you by chance have the turbo smart tee knock off, as advertised in the cincy diode mod thread, it is a piece of shit. Diodes also wear out. If you find that either one of those things are the result of your issues after you take out the turbo (you shouldn't) I take no responsibility for the wasted labor time :)
joenelson7687 Aug 18, 2010 10:51 PM
How do I know if I have the knockoff?
onepoint8tee Aug 18, 2010 11:43 PM
It wouldn't look exactly like this
http://www.turbosmartonline.com/images/1035.jpg
joenelson7687 Aug 18, 2010 11:51 PM
Pshew...I'm good. It's the real deal. I have a 24 hour duty tomorrow (army stuff) but I'll have the turbo out on friday and post back. BTW, thanks a million for all the help. I owe ya!
joenelson7687 Aug 20, 2010 09:20 PM
I AM FUCKING LOST!!!!!!!!!!!!!! So I was driving home today from work. I was at a stop light, when to go and BAM...I had boost. I had it all the way home. I pulled my car into the drive way, turned the car off. I came back out, turned it on and then nothing....no more boost. I am so confused...
onepoint8tee Aug 20, 2010 09:56 PM
Hmmm. I'm onto something else here. Can't believe I didn't see it before.... That P0011 cam code could have to do with a bad cam chain tensioner. 2001 engines have a solenoid for the cam adjuster (vvt). If the cam chain tension was lose (due to a bad tensioner), it could cause the vvt "solenoid" to register that code.... and maybe limp with 0 or little boost, I guess. You mentioned a clicking/ticking that goes away when you rev the engine.... The description of the noise and this fault make me real confident that your cam chain tensioner is at least 1 big problem.
A timing issue would certainly cause the ecu to want to retard timing and boost ie. limp.
Maybe it's a good thing you didn't remove the turbo. But in my experience even limp mode produced some boost, never exactly 0.
joenelson7687 Aug 20, 2010 11:26 PM
I have the cincy diode mod...I thought that meant that my car couldnt go into limp. Here's something else. On my boost gauge, at zero psi, there is a box http://www.slickcar.com/products/4303.jpg The needle actually comes to just before the box, like right on the line. I've noticed that when I actually floor it that the needle some move into the box ever so slightly...so I know that the needle is moving some. So What should be my next course of action. Should I remove the turbo and still examine the wastegate?
