Connector Identification Help
Old May 21, 2012 | 05:56 PM
moarboost's Avatar
Default Connector Identification Help
Just had the rad support and front end torn apart. Now putting it back together it will not start, no fuel at the injectors or spark. Pump primes fine and cranks fine. Coolant temp and level are hooked up. Did find one green connector that is on the same harness that comes out in front of the driver side door and runs down the fender apron. It's the same harness that has the AC fan, AC clutch connectors on it (green and beige). There is the second, larger connector and we cant remember where it was hooked into. Looked high and low but did not find another empty-ended connector. Just wanna get everything hooked up before I go looking at crank and cam position sensors.
It's a 96 2.8L 12v 5MQ.
Would somebody do me a solid and see where this connector goes? Attached pic. Thanks in advanced.
Attached Thumbnails Connector Identification Help-img_20120521_134122.jpg   Connector Identification Help-img_20120521_145604.jpg
Old May 21, 2012 | 06:18 PM
DOC_DEPALMA's Avatar
I have the same engine, looked at mine and still havent connected it to anything. Pretty sure it's wired into my headlights somewhere. At any rate that's not your issue.
Old May 21, 2012 | 06:31 PM
Also, after my ridiculous farce with my 12v rebuild etc.. I too had no spark, ended up being a combination of ICM and ECU, could be a number of things for you, just thought I'd throw that out there.
Old May 21, 2012 | 09:36 PM
FishEye's Avatar
check to see if ur crank position sensor is hooked up... that could be one of the missing connectors ur talking about... also it should be color coded so just keep looking around for loose wires hanging around.. you'll find it eventually u just gotta look harder... maybe try looking from under the car
Old May 22, 2012 | 07:06 PM
moarboost's Avatar
Thanks guys. I've looked high and low and there is no sign of the other end.
The car sat for about a month but ran fine before I parked it. The scanner is able to read just about everything except crank position so maybe that is it.. but then again VAG Com was never able to read it even when it was running.
Old May 23, 2012 | 04:28 PM
moarboost's Avatar
Bump.. anybody definitively know? Surely I can't be the only one on the forums with the 12v.
Old May 23, 2012 | 04:47 PM
FishEye's Avatar
haha i have a 12v too... im telling u, u gotta look harder... on these vw's and audis everything is packed in a tight space so it might be hiding behind something... check behind things or take stuff out to get a better view..
Old May 25, 2012 | 08:41 PM
moarboost's Avatar
The car is an hour and a half away. I need to figure it out before I go back down there to work on it otherwise I'll spend another weekend dicking around looking for it. I appreciate your response brother. Thanks a bunch.
Old May 29, 2012 | 04:42 PM
moarboost's Avatar
Well I have looked high and low but cannot find the other end. Anybody be kind enough to check definitively?
Old Jun 1, 2012 | 12:46 PM
moarboost's Avatar
Nobody?
